max55uk Posted May 26, 2007 Share Posted May 26, 2007 Hi Guys, Problem: I have a 6 speed manual TT, being honest i hardly ever use the 6th gear as its always running around town, few days ago i noticed that my 6th gear has 'vanished', theres no crunch, or grind, nothing!!, it just will not select it self no matter how hard i try. Solution: What do i do?, is there some kind of synchro mesh i require? cost?, who supplies what? I need to get this sorted as its driving me mad, any advice will be much apreciated, Thanks in Advance Link to comment Share on other sites More sharing options...
Homer Posted May 26, 2007 Share Posted May 26, 2007 Is the stick actually going back to where 6th is, or is the 'slot' just not there? Also, be aware than 6th isn't directly backwards from 5th, it's slightly to the left (see pic) If there is a faul it's more likely to be a problem with the linkage rather than the box itself. I'd get it to someone who knows the unit's well - where abouts are you? Link to comment Share on other sites More sharing options...
D8MOA Posted May 26, 2007 Share Posted May 26, 2007 i recon sumone swaped it for a 5 speed when you wernt looking Link to comment Share on other sites More sharing options...
max55uk Posted May 26, 2007 Author Share Posted May 26, 2007 well i've tried engaging from 5th to 6th, tried different methods like you've mentioned but still no joy. Then if i try to find 6th it will engage into 4th!! Link to comment Share on other sites More sharing options...
Homer Posted May 26, 2007 Share Posted May 26, 2007 In that case it'll almost certainly be a linkage problem. Does it have a short shift kit fitted? Link to comment Share on other sites More sharing options...
max55uk Posted May 26, 2007 Author Share Posted May 26, 2007 err, well ive driven other 6 speeds seems standard, but i may be wrong. Link to comment Share on other sites More sharing options...
max55uk Posted May 26, 2007 Author Share Posted May 26, 2007 where can i obtain a linkage from? its kinda weird as the 6th gear seems 'lost' if that makes any sense. Link to comment Share on other sites More sharing options...
merckx Posted May 26, 2007 Share Posted May 26, 2007 Does 6th go in if the engine is switched off? Link to comment Share on other sites More sharing options...
Homer Posted May 26, 2007 Share Posted May 26, 2007 where can i obtain a linkage from? its kinda weird as the 6th gear seems 'lost' if that makes any sense. Get it diagnosed before you go buying parts fella. As mentioned eariler, where abouts in the UK are you? It might help recommend a place that knows the getrag. Link to comment Share on other sites More sharing options...
Scooter Posted May 26, 2007 Share Posted May 26, 2007 Have a check under the gator at the base of the shifter, there's a few other possible causes in old threads (but they are far more expensive) i think its will be something simple tbh Link to comment Share on other sites More sharing options...
Paul Posted May 27, 2007 Share Posted May 27, 2007 Isn't there some sort of plate at the base of the stick? Has this moved or previously been put on wrong? Link to comment Share on other sites More sharing options...
mr keef Posted May 27, 2007 Share Posted May 27, 2007 Have you tried when standing still with the engine off? Link to comment Share on other sites More sharing options...
Mike M Posted May 27, 2007 Share Posted May 27, 2007 Mine was like this when I first bought the car, on the test drive it was very difficult to engage 6th, Nearly put me off buying it. I used to have to wiggle it into 6th but through daily use it slackened off and is very slick now. I reckon its the linkage seizing up somewhere especially if you never use 6th. BTW the car will sit quite happily at 30mph in 6th. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted May 27, 2007 Share Posted May 27, 2007 it will be there mate, never heard of sixth gear not engagin they are tricky to find (dont rush the shift take your time and dont push to hard to the right to get it).. or you might have bought a sz converted to tt Link to comment Share on other sites More sharing options...
