Steering Wheel Wobble?
Supragal
Ok, so at 70-75 I have steering wheel wobble, I can drive through it up to about 90 where it returns. Feels exactly like the wheels are out of balance. Now that didn't make sense as they were done when I got the wheels and they had done... well... 10 miles when I found the wobble. Anyway, thought I'd best get them checked, went to Micheldever (not impressed, disaster city) and got them redone.
Still does it.
So, what else can it be? If the tracking was out and the wheels were pointing in could that cause it?
What about if the hub is out of balance? What would cause that, I mean the cars not been anywhere...
Fairly sure the discs aren't warped, breaking feels spot on.
You might have a buckled wheel? Worn suspension can sometimes cause it too, but sounds like its quite bad... Could be the spigot rings on the wheels are either missing or slightly out of shape causing the wheel not to fit on the hub perfectly centred..
Found out im missing my spigot rings and I dont have a wobble now so it shouldnt be them.
Graham dont know where I can get them from do you?
I would be incredibly suprised if it was a buckled wheel. They are BRAND new, I'm sure they would have said something today if they weren't straight?
Suspension I guess could be it, bushes etc, it's been sat for so long. How do I check, it passed it's MOT with flying colours they couldn't find anything wrong with bushes etc
WSB2 - It can't take 3 attempts to balance the wheels can it? Surely the odds of 2 places getting it wrong in exactly the same way is a long shot?
Thorin - Ok, could be, but I have no other symptoms and it's done it before and now after an MOT. Surely I'd get other symptoms? How can I check it differently?
Thanks guys
supra surj, I was wondering about alignment. Did you not get any other symptoms i.e. pulling etc? I think that's next on the list to try though.
Nic - not sure what you mean?
Yea my steering would pull randomly when coming to a stop. Felt very unstable. I still get a slight wobble at 130 :innocent:
I had a strange knocking sound from the front and a bouncy ride. The alignment sorted out pretty much all of that.
Surj
Rosie drive down to Christchurch Tyres in Bmth. Firstly they done mine and lockys car. And the guy really knows what he is doing, just say a guy was down recently with a wide grey abflug car and recommended you. I think Rikki is the guys name.
More important is that have a drive on flat bed ramp and it can take wideboys, so no clearence issues and its only £50 + VAT for alignment not sure how much they would charge to balance all 4 tyres but he will tell you exactly whats wrong and what he has changed.
May be worth the small drive, also you can book I was there for around 2hours chatting about what we could do.
http://www.christchurchtyre.co.uk/main_frame.htm
Surj
Hmm, you see I have no other symptoms at all, it drives perfectly...
Not sure mate, but at a guess i'd have thought anywhere that sells alloys should be able to get them, or contact the maker of your wheels and see what they can do. ;)
  • 5 weeks later...
Right ok, it's now been fully aligned and camber adjusted and they have balanced the wheels AGAIN.
Still doing it.
Does anyone know somewhere that will balance the wheels on the car?
What else can it be and how do I test? Could it be hubs or discs out of balance? How do I check?
Please help me!!
Did they balance the rears as well as the fronts? Last time I had a balance problem it was being caused by the rears, and not all places think to check them. Mine was caused by a defective tyre that they couldn't balance out - it got sent back to the manufacturer.
No they just did the front again. They said that it could only be the fronts causing that. Great :( Tyres are brand new, but they wouldn't be covered by warranty I'm sure. Thanks Si I will start making a list...
Has anyone reasonably local got a set of stock wheels that are proven good, who would be willing to let me put them on my car and take it up the road, that way I can start eliminating things...?
I'm having the same problems. Had 4 new tyres fitted and the car started to shudder. Had the wheels (all 4) balanced 3 times, full wheel allignment at toyota garage and they checked for other causes eg wheel bearings, suspension, but could find nothing wrong. I'm going back to the Toyota garage on Sat. and one of the technicians is coming out with me for a drive to see the problem first hand.
Out of interest what tyres do you have fitted?
Michelin Pilot sports. I can't afford to change them, if it's that then I'll have to sell it with that as a reason. Nearly £1500 of rubber. I'll be pi$$ed if they are faulty.
If I can prove the problem to be wheel related then at least I can start preparing myself for it being tyres :cry:
I had the Toyo Proxes fitted. Just thought if it was the same brand of tyres it might help with the diagnostic.
I'm 100% convinced its the tyres that are causing mine as it only started after having the new ones fitted but I will let you know if and when i get to the bottom of it.
I'm not sure about braking (don't do that much haha) but it gets better if you are on a slight bend, obviously given the speed it occurs at I'm usually on a dualy when I see it so normally straight roads but even wide sweeping bends seem to lessen the wobble.
Scooter- if you don't mind that would be brilliant, even if the fronts are out and the speed it happened at moved it would incriminate my wheels/tyres as the issue...
Nic - no spacers.
Ricky - they have been balanced by different places too now, Micheldever are meant to be really good too. I can't keep getting them done though without knowing the problem as it is looking that it isn't that :(
