kieren1234 Posted May 26, 2007 Share Posted May 26, 2007 I have a 94 na manual supra. I have just finished changing the cam covers for chrome ones and after putting all of the intake and throttle section back together and plugged all the electical plugs back in, my car is not hardly ticking over and revs are going up and down and when i rev it it is really missing, any ideas whats wrong people, im shaking because im thats bloody scared that i have buggered it!! Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted May 26, 2007 Share Posted May 26, 2007 Have you pluged the wire back into the Air filter sensor? The one near the air box?... I left mine unplugged once and it did this.. Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted May 26, 2007 Share Posted May 26, 2007 though if it's really missing then one of the plug leads might not be connected properly.. I'm guessing you took them off to change the cam cover. Are you sure you put them back on in the right order? Quote Link to comment Share on other sites More sharing options...
PAG Posted May 26, 2007 Share Posted May 26, 2007 Sounds like an ignition prob to me check all your leads etc make sure everything you took off went back on properly.I wouldnt worry about it to much sure its nothing serious. Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted May 26, 2007 Author Share Posted May 26, 2007 Thanks for the help. The plugs are fine and leads are connected fine aswell, and the air filter sensor is plugged in. EVERY thing as far as i can see is back just the way it come off. Quote Link to comment Share on other sites More sharing options...
SatSport Posted May 26, 2007 Share Posted May 26, 2007 did you disconnect any of the water hoses? Water near the plugs will do this. Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted May 26, 2007 Share Posted May 26, 2007 I agree, wouldn't think it's anything serious. If it was working before then it's obviously something to do with changing the cam cover. Have you fitted the cam breather pipes properly? Can you hear any hissing (vacuum leaks?).. Oh & you didn't dismantle the throttle body did you? Are you sure you've not got a couple of leads the wrong way round? Did you label them when you took them off? Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted May 26, 2007 Share Posted May 26, 2007 SatSport said: did you disconnect any of the water hoses? Water near the plugs will do this. Good point, there isn't coolant leaking from the throttle body into the plug holes is there?.. You should be able to see/feel if there is... Quote Link to comment Share on other sites More sharing options...
JODY T Posted May 26, 2007 Share Posted May 26, 2007 Hmmm... Did you use new gaskets when you refitted it? May have an air leak.... Quote Link to comment Share on other sites More sharing options...
Matt _Aero top_ Posted May 26, 2007 Share Posted May 26, 2007 funny one this i changed my plugs the other day on my N/A and that started to miss , but once it warmed up it went away and has been fine ever since , But my guess is you got a plug lead on the wrong way or you didn't push it on properly at the sparkplug end , did you take the dizzy cap off ? Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted May 26, 2007 Author Share Posted May 26, 2007 thanks guys. Have just checked everything and the spark plugs were piss wet through, so dried them all out, took them out and cleaned them but the car wont even idle, its just cuts out and sounds aweful when revving it, took it for a little drive and it just seem buggered to me, i dont know what to do because i have no money to get someone to have a look at it and no idea whats wrong!!. Quote Link to comment Share on other sites More sharing options...
SatSport Posted May 26, 2007 Share Posted May 26, 2007 damp still in the leads/electrics..... wouldn`t worry it`ll dry out ok. Quote Link to comment Share on other sites More sharing options...
DannyW Posted May 26, 2007 Share Posted May 26, 2007 SatSport said: damp still in the leads/electrics..... wouldn`t worry it`ll dry out ok. get some wd40 on the plugs and the ends of the leads. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 26, 2007 Share Posted May 26, 2007 Sounds like a vacuum leak to me, possibly the fuel pressure regulator, have you checked for any splits in the pipes? or forgotten to reconnect one? Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted May 26, 2007 Share Posted May 26, 2007 Similar thing happened to mine after a bad power washing incident... I had to take all the spark plugs out, then use rolled up kitchen roll to shove down the holes to soak up all the water. It took ages but it was the only way i could dry them out. WD40 alone wouldn't work & i'd tried leaving it for ages but it just wouln't dry out on its own... Quote Link to comment Share on other sites More sharing options...
Al Massey Posted May 26, 2007 Share Posted May 26, 2007 post lots of pics up and well see if we can see owt wrong Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted May 26, 2007 Author Share Posted May 26, 2007 Hi all, thanks again. It ended up to be a combination of wet plugs and leads, and the vaccum hose that goes into the inlet manifold on the right section, the nipple had snapped off it so the hose was not connected up. Went and got a few bits off my spare engine in the garage and it is even better than before now, also the inlet manifold had a crack in it so replaced this with a spare one. Top advise guys, very very much appreciated. Quote Link to comment Share on other sites More sharing options...
flukey-lukey Posted May 26, 2007 Share Posted May 26, 2007 Glad you got it sorted having a spare engine comes in handy eh! Quote Link to comment Share on other sites More sharing options...
kieren1234 Posted May 26, 2007 Author Share Posted May 26, 2007 Cheers luke. I would be buggered without that spare engine ha ha. Quote Link to comment Share on other sites More sharing options...
