Dr_Doom Posted May 26, 2007 Share Posted May 26, 2007 I fitted a new horn the other day which went ok, but i had to squeeze my hand down in-between the top secret bumper & the radiator in order to disconnect the old noddy style horn.. In the process i accidentally chopped this off (see pic) Anyone know what it is? and do i need to re-attach it? Looks like some sort of sensor. It doesn't seem to have made any difference so far.. Quote Link to comment Share on other sites More sharing options...
carl0s Posted May 26, 2007 Share Posted May 26, 2007 No idea. What do crash-impact sensors for setting off the airbags look like? Quote Link to comment Share on other sites More sharing options...
Ric Posted May 26, 2007 Share Posted May 26, 2007 outside air tempreture sensor, only uk cars use it, shows outside temp in the clock, all cars have the wiring for it though. Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted May 26, 2007 Author Share Posted May 26, 2007 Cheers.. I'll be leaving that unplugged then Quote Link to comment Share on other sites More sharing options...
PAG Posted May 26, 2007 Share Posted May 26, 2007 so if i bought the correct sensor i would get outside temp on my j-spec clock? Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted May 26, 2007 Author Share Posted May 26, 2007 By the sounds of it, everyone has the sensor, but only the UK clock utilizes it?.. not sure really Quote Link to comment Share on other sites More sharing options...
mawby Posted May 26, 2007 Share Posted May 26, 2007 No, you would need a UK clock which has a button to switch between displaying the time and outside temp. Quote Link to comment Share on other sites More sharing options...
Mike M Posted May 26, 2007 Share Posted May 26, 2007 I think you'll still need a UK spec clock. Still food for thought though. Quote Link to comment Share on other sites More sharing options...
uk-rich Posted May 26, 2007 Share Posted May 26, 2007 i have a uk spec clock here, surplus to my needs, has been carbon coated by nic Quote Link to comment Share on other sites More sharing options...
Sheefa Posted May 27, 2007 Share Posted May 27, 2007 i have a uk spec clock here, surplus to my needs, has been carbon coated by nic I'll give you a quid for it.......................and a kick in the nuts Quote Link to comment Share on other sites More sharing options...
PAG Posted May 27, 2007 Share Posted May 27, 2007 Yep found the sensor today:) Quote Link to comment Share on other sites More sharing options...
Glosphil Posted May 27, 2007 Share Posted May 27, 2007 Does it need different wiring for the uk spec clock? if it doesnt, I'd be interested in that Rich Quote Link to comment Share on other sites More sharing options...
Sharpie Posted May 27, 2007 Share Posted May 27, 2007 note: Sensor is shown upside down Quote Link to comment Share on other sites More sharing options...
PAG Posted May 28, 2007 Share Posted May 28, 2007 As asked by Glosphil are the connectors on both clocks the same? Quote Link to comment Share on other sites More sharing options...
