Front sub frame wanted
Whitesupraboy2
Rear end shunt? and you want the front subframe??
Got a rear one somewhere..... not much help really... you could have it for nadda if you want..
was meant to be commical like an Advert...that those insurance people do. Just to be clear ive had no shunt!! :D Just doing my wheel alignment today brought up some interesting things. (wait till you see the sheet Gav :rlol:
so why is ure chassis bent.
Chassis itself is not bent, I was worried it had been in front end damage but not recorded but there is no evidence of that and the damage doesnt support that either. The part where the camber is attached to the subframe has twisted slightly but makes it impossible to adjust.
Whilst under the car i searched for evidence of why this has occured and i found that an alloy bit in front of it had been flattened I.e like grounding
So at some point the car has bottomed out. this was before I got it and I know when this was,I think it may of been when Robert's wheel fell off after getting the car back initally.
so you went to christchurch tyres for your wheel alignment then?
yep, great blokes I must say and know exactly what they are doing. My handling has improved loads even with the castor problem.
apparently yours is about a cm wider, they remembered by the squeeze of getting your wheels on. :D
He only charged me £40 to put on 2 new tyres and have an alignment (took 2 hours he tried everything!). But when I go back next time I'll pay £30 to make it up to £50. But I thought that was very good of him to do that because he didnt have too.
I will not be taking any of my cars anywhere else I was really impressed... although when you first turn up the drive in scares you doesnt it :scare: :faint:
apparently yours is about a cm wider each side, they remembered by the squeeze of getting your wheels on. :D
double post lol,
yep.
i was thinking another back alley place, and oh no, that doesnt look good for the car.
its good its just drive on, and in not sure who did yours, but the guy is great, you can hang on and have a chat with him, and he even tells you what he has done, etc etc.
he recomended that i get the adjustable top mounts for my teins, as he couldnt get the fronts set up perfect. and that this would help miles,
my rears are sitting flat, but the difference you feel when you drive the car out was amazing, such a light steering wheel, as before it was extreemly heavy.
although i did add 8inches lmao:d
