Armoured electric cable question
Chris Wilson
I need to run mains single phase power to the new land we have bought, a distance of about 150 metres from a workshop with a decent mains power feed into it. I want to use 3 core armored and bury it. I need to run a normal 13 amp socket at the field end. What size cable do I need, and is it readily available in more than a 50 metre uninterupted length? On Ebay most seem to be advertising 50 metre lenghts, I'd rather not ahve to try and make a waterproof undergound joint.
Are there waterproof lockable boxes available, I'd want the 13 amp mains power socket in it, and a 12 x 10 x 6 electric fence energiser in it, too?
Thanks.
I can't answer many of your questions but I do know that there is a formula for the voltage drop along thelength of cable for a cable of a given size. The electric regs state that the voltage drop can't be any more than a certain amount.
You need to know the total load in W (or the total current in amps) that you will be pulling through the cable. You plug that plus the length into the equation and it will tel you what size cable you need.
There are some pretty good DIY forums about but a lot of them will just point you in the direction of an electrician these days because a lot of work is "notifiable" under the new regs, which prevent you from doing a lot of electrica DIY these days.
Further since the explosion :D
But how far away is the shed?
:rlol:
Hahahahahahha
It is about 10m of cable length to be fair, but I'm also putting a fair load on it with the welder so I'd rather be safe than sorry with an underground cable melting.
Try and get some Hawk Ex 'd/e' glands or some sort of IP 68 rated glands for the cable entry into the JB's as they will almost guarantee no moisture ingress over the years. The Hawk glands are def overkill but they do make off the wire/ braided armour nicely and being brass they wont seize up so quick.
Not sure on cable size tho for that sort of voltage.
right go to c.e.ff city electrical factors they can should be able to help for a 150m run id put in at least 4mm and you may want to run a coms cable at the same time you never know net acess and all that;) were no one can see.!!!!
they will also do the right type of glands..etc.. or edmonsons not to bad,,:)
Thanks.
You can buy lockable isolator swtich boxes and they are water proof - IP55/65.
How many sockets are you wanting to have and how much current does the fence enegiser use ?
You can save money on whatever size cable you want by using two core armoured as you should earth the armoured part anyway.
A good electrical wholesale place should be able to get you any size upto a 500 meters
Also you can work out volt drop and factors here http://www.ktassemblies.co.uk/technical.html
It has no table for armoured but you know what i mean.
The bureaucrats introduced red tape in 2005 that stops you from doing any elecrical work like this unless you're a registered sparky-nician. If you do the work yourself you have to find one who will certify it as a job well done. Apparently.
use some red and black cable then its anyones guess when it was done.
Depends on the load at the other end.
A 4mm cable at 150m will carry about 1.5KW without too much of a volt drop at the other end, any more then you should look at getting some 6mm cable.
So if its just a few lights and light tools 4mm but if you want a kettle and toaster in the shed get some 6mm
Thinks its about £1.90 a metre form lockwells/edminsons etc and they will cut it too length
Get some of the old colours if you can as it loads cheaper, got this for my garden.
As far as the new colours letting them know when it was done, they were selling the new colours six mths to a year before bringing in the regs so it's no real gauge on the time it was fitted.
dont for get to dig the trench deeper than 18" or more and then put plastic id marking tape over it..!! find a local sparks to test it when done dont want to blow the missus up now do we!!:innocent:
just make sure you follow the regs.. loads of info, people can get killed if not done right and its your neck on the block!!!! if you dont have it tested.. or there neck !!;)
  • 2 weeks later...
