johnd-mkiv Posted May 24, 2007 Share Posted May 24, 2007 I have installed a greddy turbo timer but have a clifford alarm fitted I cant seem to over ride the alarm to arm it self after the car has shut down has any one managed this yet?? Quote Link to comment Share on other sites More sharing options...
Angarak Posted May 24, 2007 Share Posted May 24, 2007 I dont think you can run a 3rd party turbo timer with a clifford alarm. You can however get a clifford turbo timer added to your alarm as an optional extra - well you can on some models anyhow like the 650P Concept. Quote Link to comment Share on other sites More sharing options...
tomssupra Posted May 24, 2007 Share Posted May 24, 2007 Angarak, Do you know where I can get that? is it something i can fit? Thanks Quote Link to comment Share on other sites More sharing options...
Angarak Posted May 24, 2007 Share Posted May 24, 2007 Anyone who sells/fits clifford alarms should be able to provide you with one, but confirm with them beforehand that your model of clifford does support this addon. Im not sure if its something you'll be able to fit, or if they (clifford installer) insist on fitting it for you. You may also need a new remote fob, again depends on the model of clifford you have. Quote Link to comment Share on other sites More sharing options...
tomssupra Posted May 24, 2007 Share Posted May 24, 2007 its the 650P, i cant find it on google, would you happen to know how much im looking at to have that fitted? Quote Link to comment Share on other sites More sharing options...
Angarak Posted May 24, 2007 Share Posted May 24, 2007 I think it was around an additional £40 at the time mate, though this may vary from installer to installer. If you have the 650P, the alarm does support the clifford turbo timer and you wont need a new remote. Quote Link to comment Share on other sites More sharing options...
Fargo Posted May 24, 2007 Share Posted May 24, 2007 why not simply set the clifford to auto arm in x amount of time.. then all you gota do is manually lock the car before you walk away. Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted May 25, 2007 Share Posted May 25, 2007 Mine runs a Clifford 650 and I have a Blitz Turbo Timer, they work in harmony together, no probs at all. I didn't want to use the clifford function as it is a set time only, my turbo timer configures the length of time to run, dependent upon the abuse I have given the car. Quote Link to comment Share on other sites More sharing options...
boomstick Posted May 25, 2007 Share Posted May 25, 2007 I dont think you can run a 3rd party turbo timer with a clifford alarm. A decent clifford-dealer can get it to work without any problem! I have a clifford 600 with a Blitz turbotimer. Th Blitz unit has loads of gadgets (turbo-pressure/different time settings/recording), but you probably won't use them. As the Blitz would add an other item to youre dash, I would go for the Clifford turbotimer option. I already have to much going on on the dash Quote Link to comment Share on other sites More sharing options...
Ric Posted May 25, 2007 Share Posted May 25, 2007 its not a turbo timer as such from clifford the installer will add 2 4 pin relays and just wire them to a aux from the alarm as the trigger, all what it does is keep the ign feed to the engine to keep it running for however many seconds, its not a turbo timer "box" as such, just 2 relays Quote Link to comment Share on other sites More sharing options...
supragold Posted May 27, 2007 Share Posted May 27, 2007 I had World of ice in Colchester fit my clifford and try to connect it with my HKS turbo timer. What a bunch of C**ts. They had no idea. I will never ever go there again for anything. Bare wires everywhere and an all round f**k up. Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted May 28, 2007 Author Share Posted May 28, 2007 Mine runs a Clifford 650 and I have a Blitz Turbo Timer, they work in harmony together, no probs at all. I didn't want to use the clifford function as it is a set time only, my turbo timer configures the length of time to run, dependent upon the abuse I have given the car. I was told this by the clifford dealer too thats why i went for the after market unit, ill pop down to them and see if they can over ride it as it sounds possible Quote Link to comment Share on other sites More sharing options...
Angarak Posted May 28, 2007 Share Posted May 28, 2007 FYI, the clifford 'turbo timer' runs for 2 minutes (well, mine does anyhow), though Im sure the dealer said it could be altered, but as mentioned some 3rd party turbo timers will auto-adjust the running time depending on engine temp...whereas the clifford will just run for x amount of time regardless. I've never found this a problem personally as I always ensure Im not giving it death upto the point of parking the car up, so 2 minutes is plenty as far as Im concerned. Quote Link to comment Share on other sites More sharing options...
Guest Chumpalot Posted July 2, 2007 Share Posted July 2, 2007 sorry to bring up an old (ish) thread, thought it would be better than starting a new one. I have a Greddy Turbo Timer and have it set on a minute cool-down. I can't enable the alarm until the car has shut down and wondered if it would be ok to lock the car manually? That way I could just walk off and not have to hang around. Thanks for the help. Dave Quote Link to comment Share on other sites More sharing options...
gaz1 Posted July 2, 2007 Share Posted July 2, 2007 http://www.mkivsupra.net/vbb/showthread.php?t=116474 this one does it i believe:D;) Quote Link to comment Share on other sites More sharing options...
Tourniquet Posted July 2, 2007 Share Posted July 2, 2007 So guys, after all the posts, is it actualy possible for the alarm to arm properly (as if u'd pressed the button) by itself after the timer has counted down as apposed to passive imobilser arming ? I was told by Gap it wasn't as I wanted this feature, and even if it was it would void the Cat 1 class. Has this changed or certain models been developed to do this or was he just plain wrong ??? I would most certainly be interested in one - especially with Intel start. There's nothing worse than waiting for it to cool down before leaving or having to come back to arm it. Seems senceless as the anti theft wire to the handbrake does the first part for you. Quote Link to comment Share on other sites More sharing options...
