Guest TP_ Posted May 24, 2007 Share Posted May 24, 2007 Hello. Tomorow im going to build up an so called restrictor ring to my Jap spec Supra. I couldnt find any info of the size of the hole on swedish Supra forums, so i hope someone here knows. Iv´e heard of that the hole in it should be 2 inches, but a few other rumors say it should be 2 and a half inch (2.5"), so the boost wont get over 1.2bar (0.8 is the stock boost, aint it?). I hope to get a few good answers! Regards, Mattias from Sweden. Quote Link to comment Share on other sites More sharing options...
r1george Posted May 24, 2007 Share Posted May 24, 2007 Hi, 50mm will give you about 0.9-1.0bar and 52mm is about 1.1bar. Hope this helps;) Quote Link to comment Share on other sites More sharing options...
Guest TP_ Posted May 25, 2007 Share Posted May 25, 2007 Yes, it does help . Ill just make a little bit larger than 52, maybe 54mm. Ill be back later to tell if it worked out! //Mattias Quote Link to comment Share on other sites More sharing options...
wallis Posted May 25, 2007 Share Posted May 25, 2007 Hello. Tomorow im going to build up an so called restrictor ring to my Jap spec Supra. I couldnt find any info of the size of the hole on swedish Supra forums, so i hope someone here knows. Iv´e heard of that the hole in it should be 2 inches, but a few other rumors say it should be 2 and a half inch (2.5"), so the boost wont get over 1.2bar (0.8 is the stock boost, aint it?). I hope to get a few good answers! Regards, Mattias from Sweden. i have a 3.5" straight through custom built exhaust with a 50.5mm RR fitted where the sec cat normally goes in, this gives me just under 1.2 bar. i would say 54mm will possibly send u over slightly so be carefull other wise u will making another one! its always better to start smaller than bigger at least u can sort it out that way mate Quote Link to comment Share on other sites More sharing options...
Cable Posted July 14, 2007 Share Posted July 14, 2007 Just fitted both decats today with a 50mm restrictor ring and hitting 1bar though it's been a little warmer today so I'll go out tonight when it's cooler and see if there is a slight increase. Even so I want to be running 1.2 so I'll be going for a 52-53mm and see how it goes. Quote Link to comment Share on other sites More sharing options...
Armin Posted July 14, 2007 Share Posted July 14, 2007 i had about 58mm 1,2-1,25bar Quote Link to comment Share on other sites More sharing options...
Matti85 Posted July 15, 2007 Share Posted July 15, 2007 What material is the ring made off, Copper or Plate. Dont know if Copper can handle the temprature that the exhaust comes up to, so figure it have to be plate. In case i try to make one myself Quote Link to comment Share on other sites More sharing options...
Armin Posted July 15, 2007 Share Posted July 15, 2007 standard steel plate, say 2mm Quote Link to comment Share on other sites More sharing options...
paul mac Posted July 15, 2007 Share Posted July 15, 2007 every car will be different, i would start small and work your way up till you get what you want Quote Link to comment Share on other sites More sharing options...
