Pete Posted May 24, 2007 Share Posted May 24, 2007 I've checked the HORN-HAZ fuse in the engine - that's fine. Normal indicators are fine. Removed the hazard connector, reconnected. The CJ Supra manual suggests its the loom - but where to start?! I'm sure they did used to work and I've done no rewiring since. Ideas please anyone? Thanks. Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 24, 2007 Share Posted May 24, 2007 Check the switch on the top of the dash area... might be on the blink (no pun intended) Quote Link to comment Share on other sites More sharing options...
Pete Posted May 24, 2007 Author Share Posted May 24, 2007 Do you mean the hazard switch itself? How can I check this other than what I've already done by removing and refitting? Maybe I need a known good one. Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 24, 2007 Share Posted May 24, 2007 Do you mean the hazard switch itself? How can I check this other than what I've already done by removing and refitting? Maybe I need a known good one. Yup, exactly, loan one and just replace yours to see if it works.. just eliminates another possibility and it is an easy one to check... Quote Link to comment Share on other sites More sharing options...
SteveR Posted May 24, 2007 Share Posted May 24, 2007 Hmmmm. Not sure if this helps or not Pete, but if the Hazard warning switch is disconnected (not sure about just 'playing up') then the indicators don't work either - i.e. when you use the indicator stalk nowt happens. I found this out when I delimited mine and went out for a test run mid-install. If* the same goes for when it's playing-up, then it's not the switch - assuming your indicators are still working. * = That's the bit I don't know however. Quote Link to comment Share on other sites More sharing options...
Pete Posted May 24, 2007 Author Share Posted May 24, 2007 Yup, exactly, loan one and just replace yours to see if it works.. just eliminates another possibility and it is an easy one to check... Looks like I may have to. I've done a continuity check using an Ohmmeter as per the manual, that comes up ok though. If* the same goes for when it's playing-up, then it's probably not the switch - assuming your indicators are still working. * = That's the bit I don't know however. I took the switch off and tried the indicators just to double check that one out. Indicators do indeed work fine, as does the horn which shares the same fuse. Bloody great. Hopefully someone won't mind taking their dash off on Sat? Quote Link to comment Share on other sites More sharing options...
Paul Posted May 24, 2007 Share Posted May 24, 2007 Wow, I had this exact thing happen on mine a couple of years back. I paid an auto electrician to sort it and he came to the conclusion that the hazard part of the loom was at fault either deep in the dash or worse. What he did was run a new positive from the drivers footwell fuse panel, put an in-line blade fuse holder on and take it up to the switch. In his and my opinion it was a tidy yet simple way to cure it without stripping half the dash out. Paul Quote Link to comment Share on other sites More sharing options...
Pete Posted May 24, 2007 Author Share Posted May 24, 2007 Wow, I had this exact thing happen on mine a couple of years back. I paid an auto electrician to sort it and he came to the conclusion that the hazard part of the loom was at fault either deep in the dash or worse. What he did was run a new positive from the drivers footwell fuse panel, put an in-line blade fuse holder on and take it up to the switch. In his and my opinion it was a tidy yet simple way to cure it without stripping half the dash out. Paul Thanks VERY much for the input. It prompted me to check for a permanent live (which I should've thought about before - DOH!). There isn't one! I guess I'll be doing similar then. There's one right next door to it so I'll do some fudging tomorrow and cross my fingers. That's very odd though, I'm going to study the wiring plans and see if I can figure out where the perm live originates. Quote Link to comment Share on other sites More sharing options...
Paul Posted May 24, 2007 Share Posted May 24, 2007 At least you've sussed out why now. I know I was shocked when mine went, I hardly ever use hazards and then I tested them days before the MOT. Must be a weak point somewhere, be interesting to know where it is? Alot easier to run a new live to it with a fuse though, you can always lash something up temporary to get it through the MOT though. Glad it helped mate Paul Quote Link to comment Share on other sites More sharing options...
pistonbroke Posted May 25, 2007 Share Posted May 25, 2007 I thought the indicators didn't work at all when the hazard switch was disconnected as it completes the circuit when plugged in, yet yours still work when its un-plugged.? When you arm your alarm, do all the indicators flash? Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted May 25, 2007 Share Posted May 25, 2007 I had a similar problem when my drivers side window stopped working Pete. Turned out the connector block in the foot-well fuse box had become corroded over time. Worth a look (as it took me ages messing about with fuses before I realised) Quote Link to comment Share on other sites More sharing options...
Pete Posted May 25, 2007 Author Share Posted May 25, 2007 I thought the indicators didn't work at all when the hazard switch was disconnected as it completes the circuit when plugged in, yet yours still work when its un-plugged.? That's correct, no indicators at all when disconnect. When you arm your alarm, do all the indicators flash? Yup. I had a similar problem when my drivers side window stopped working Pete. Turned out the connector block in the foot-well fuse box had become corroded over time. Worth a look (as it took me ages messing about with fuses before I realised) I don't think it's fuse or fusebox related as it shares a fuse with the horn an that works fine. I'll do the perm live mod tonight. Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted May 25, 2007 Share Posted May 25, 2007 it shares a fuse, but does it share the power wire post fuse? Quote Link to comment Share on other sites More sharing options...
Pete Posted May 25, 2007 Author Share Posted May 25, 2007 it shares a fuse, but does it share the power wire post fuse? Errrr....it's not the same thing? I need to study the wiring diags a little more and see what the horn shares I think. Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 25, 2007 Share Posted May 25, 2007 A bit later tonight, I'll dig out the wiring diagrams for the VVTi and have a look for you Pete, if I don't respond by about 9ish tonight give me a nudge... Quote Link to comment Share on other sites More sharing options...
Pete Posted May 25, 2007 Author Share Posted May 25, 2007 A bit later tonight, I'll dig out the wiring diagrams for the VVTi and have a look for you Pete, if I don't respond by about 9ish tonight give me a nudge... Thanks - I appreciate it. I only have the CJ Manual ones. Quote Link to comment Share on other sites More sharing options...
Pete Posted May 25, 2007 Author Share Posted May 25, 2007 Interestingly I can see the White permanent 12v travels through two other connectors on the way to that switch. IB2 then IF1 - both in the drivers foot well. I can see some upside down shenanigans in the morning. I'll see if they're receiving power. Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted May 26, 2007 Share Posted May 26, 2007 Pete, my thinking was it needs to be one wire leading to the fuse, but then two afterwards (one power to the horn and one power the indicator switch) - my money is definitely on one of the connector blocks! Quote Link to comment Share on other sites More sharing options...
Pete Posted May 26, 2007 Author Share Posted May 26, 2007 Pete, my thinking was it needs to be one wire leading to the fuse, but then two afterwards (one power to the horn and one power the indicator switch) - my money is definitely on one of the connector blocks! Mine too now I know they exist I've got up late, will let you know after eating my sausage and egg sandwich. I bet CW has already got up and built half the perimeter fence with his rented JCB for his mutant shaggy cows by now, whilst I can't even look at a connector. Quote Link to comment Share on other sites More sharing options...
Pete Posted May 26, 2007 Author Share Posted May 26, 2007 I ran a 12v perm to the back of the switch just to test and it works. I'm damned if I can find these junction connections as listed in the manual - but I am looking at pre VVTi data. Maybe what I'm looking for simply isn't there. For instance - the OBDII connector on the drivers under panel isn't connected to anything!? (unlike the diagram) Quote Link to comment Share on other sites More sharing options...
