madmike Posted May 24, 2007 Share Posted May 24, 2007 anyone know how the passenger air bag comes out ?i am sure its easy but wanted to check before i started cheers Quote Link to comment Share on other sites More sharing options...
edge Posted May 24, 2007 Share Posted May 24, 2007 I Can drive into the front of your car if you like. And i will only charge you a few beers Quote Link to comment Share on other sites More sharing options...
JustGav Posted May 24, 2007 Share Posted May 24, 2007 Very carefully is a start.. If you remove the lower glove box, you will see the yellow trigger wires, I would suggest unplugging those and leaving it for a good while (10 mins +), the bolts for the airbag will also be accessible from the lower glove box area. Quote Link to comment Share on other sites More sharing options...
madmike Posted May 24, 2007 Author Share Posted May 24, 2007 Very carefully is a start.. If you remove the lower glove box, you will see the yellow trigger wires, I would suggest unplugging those and leaving it for a good while (10 mins +), the bolts for the airbag will also be accessible from the lower glove box area. cheers for that will try in a bit:D Quote Link to comment Share on other sites More sharing options...
madmike Posted May 24, 2007 Author Share Posted May 24, 2007 I Can drive into the front of your car if you like. And i will only charge you a few beers wow thats really kind of you to offer Quote Link to comment Share on other sites More sharing options...
Guest andyj22 Posted May 24, 2007 Share Posted May 24, 2007 Its a really easy task to do. Disconnect negative terminal on battery. Wait 10 mins. Quote Link to comment Share on other sites More sharing options...
