Oil – You get what you pay for!
oilman
Costs of synthetics vary considerably. The most expensive are the “Ester” types originally only used in jet engines. These cost 6 to 10 times more than high quality mineral oils.
The cheapest synthetics are not really synthetic at all, they are dug out of the ground and not manmade. These are in fact specially refined light viscosity mineral oils known as “hydrocracked” oils.
“Hydrocracked” oils have some advantages over their equivalent mineral oils, particularly in lower viscosity motor oils such as 5w-30 and 5w-40 and they cost about 1.5 times more than good quality mineral fractions. This is the “synthetic” which is always used in cheap oils that are labelled “synthetic”.
So, why are these special mineral oils called “synthetic”?
Well, it all came about from a legal battle that took place in the USA more than ten years ago. Sound reasons (including evidence from a Nobel Prize winning chemist) were disregarded and the final ruling was that certain mineral bases that had undergone extra chemical treatments could be called “synthetic”.
Needless to say, the marketing executives wet their knickers with pure delight! They realised that this meant, and still does, that the critical buzz-word “synthetic” could be printed on a can of cheap oil provided that the contents included some “hydrocracked” mineral oil, at a cost of quite literally a few pence.
So, the chemistry of “synthetics” is complex and so is the politics. The economics are very simple though.
If you like the look of a smart well-marketed can with “synthetic” printed on it, fair enough, it will not cost you a lot; and now you know why this is the case, it’s really only a highly processed mineral oil.
But, if you drive a high performance or modified car, and you intend to keep it for several years, and maybe do the odd “track day” or “1/4 mile”, then you need a genuine Ester/PAO (Poly Alpha Olefin) synthetic oil.
These oils cost more money to buy, because they cost a lot more money to make.
Very simply, you always get what you pay for, cheap oils contain cheap ingredients, what did you expect!
Very interesting! Im a firm believer of 'you get what you pay for' and with cars this is especially true for oil!
Do you rate Royal purple at all? Looked into it a few months ago, mainly the LSD and gearbox oil???
You are quite right.
We dont do royal purple though.
Have a look at the Silkolene Syn5 75w-90 for the diff. Have you got a 5 or 6 speed?
Cheers
Guy.
Motul Chrono 300V all the way, I've used this on my last three cars as recommended by oilman many moons ago. My car is running stock and is never tracked, but used everyday. Every three months the oil is changed, when draining its still got its gold colour to it, I've never had this with any other oil.
I can't recommend this stuff highly enough.
can you collect the "old" oil and i'll pick it up from you every few years ?:D
