dibbleyuk Posted May 24, 2007 Share Posted May 24, 2007 Hey peps, Lately ive been messing about in the supra over my uncles yard donuts, burnouts etc thing is its seems to (as my mate put it) Wheel tramp quite abit. When its getting going it seems as if the rear end is quite violently bowncing/jumping, i dont want to hurt it and was told the best thing is to get the rear polybushed. Is that correct if so where can i get them and how much is it likely to cost. Can anyone also explain what is happening here as i dont know much about it. Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 24, 2007 Share Posted May 24, 2007 Hey peps, Lately ive been messing about in the supra over my uncles yard donuts, burnouts etc thing is its seems to (as my mate put it) Wheel tramp quite abit. When its getting going it seems as if the rear end is quite violently bowncing/jumping, i dont want to hurt it and was told the best thing is to get the rear polybushed. Is that correct if so where can i get them and how much is it likely to cost. Can anyone also explain what is happening here as i dont know much about it. Demon tweaks sell these as I was looking at them this morning in their brochure, they are £145 front and £146 rear if remember right ! I am sure a trader on here will come alomg and top this though ! Link to comment Share on other sites More sharing options...
miko_supra Posted May 24, 2007 Share Posted May 24, 2007 i thought the biggest cause of tramping was soft suspension, and that stiffening it would resolve this AFAIK Link to comment Share on other sites More sharing options...
matt k Posted May 24, 2007 Share Posted May 24, 2007 Larkspeed do a full set for £227 afair they have a listing on Ebay. Link to comment Share on other sites More sharing options...
JamieP Posted May 24, 2007 Share Posted May 24, 2007 I was suffering with a lot of wheel hope when wheel spinning, poly bushes all round cured the problem for me as would have new oem bushes im sure. Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 24, 2007 Share Posted May 24, 2007 may be worth giving Elitedirect motorsport a call in Rainham Essex as they do the work as well ?? Link to comment Share on other sites More sharing options...
dibbleyuk Posted May 24, 2007 Author Share Posted May 24, 2007 Fitting isnt a problem for me mate i just wanted to know the cause whats going on etc etc and what will stop it because i didnt know much about it. Keep it comming guys im learning here Link to comment Share on other sites More sharing options...
JamieP Posted May 24, 2007 Share Posted May 24, 2007 Be warned the polys are a PIG to fit and Turbofit told me they would not take another poly bush fitting job on again. Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 24, 2007 Share Posted May 24, 2007 Be warned the polys are a PIG to fit and Turbofit told me they would not take another poly bush fitting job on again. I was just going to ask them as well as it is sitting at TF waiting for parts Link to comment Share on other sites More sharing options...
dibbleyuk Posted May 24, 2007 Author Share Posted May 24, 2007 nothings impossible though i dont mind getting dirty i know a dam good mecahnic with 30k's worths of tool we should be fine lol Link to comment Share on other sites More sharing options...
Thorin Posted May 24, 2007 Share Posted May 24, 2007 How much is it for a full set of new OEM bushes? Link to comment Share on other sites More sharing options...
Homer Posted May 24, 2007 Share Posted May 24, 2007 How much is it for a full set of new OEM bushes? I'm sure you can't get them seperate, you have the buy the entire arm. The thing is, if you bushes are worn, so with the ball joints in the arm, so just replacing the buches is a bit of a half job. I'd go for new arms from Toyota, if you fit them yourself it'll more than likely work out cheaper than using poly bushes anyway (plus you'll have better ride comfort). Link to comment Share on other sites More sharing options...
Thorin Posted May 24, 2007 Share Posted May 24, 2007 I'm sure you can't get them seperate, you have the buy the entire arm. The thing is, if you bushes are worn, so with the ball joints in the arm, so just replacing the buches is a bit of a half job. I'd go for new arms from Toyota, if you fit them yourself it'll more than likely work out cheaper than using poly bushes anyway (plus you'll have better ride comfort). Alright how much for them then? Link to comment Share on other sites More sharing options...
Homer Posted May 24, 2007 Share Posted May 24, 2007 Alright how much for them then? Ian C mentioned £950 here: http://www.mkivsupra.net/vbb/showpost.php?p=1426991&postcount=84 If I've understood it correclty from Ian thats for every last bit, including new bolts, etc. I was quoted around £500 labour to change all bushes, so works out around £800 total for polys. But then you still have the old arms, ball joints, bolts, camber pins, etc Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 24, 2007 Share Posted May 24, 2007 I won't fit them either, just for the record Not unless someone wants to pay double the hourly rate, anyway Link to comment Share on other sites More sharing options...
Guest mk47 Posted May 24, 2007 Share Posted May 24, 2007 right bastard those bushes. I just had a quote from toyota aswell and homer is pretty mcuh right they come close to a grand. Link to comment Share on other sites More sharing options...
dibbleyuk Posted May 24, 2007 Author Share Posted May 24, 2007 Jesus i didnt think it could be that hard a job! Can anyone explain why they are so hard? Link to comment Share on other sites More sharing options...
Homer Posted May 24, 2007 Share Posted May 24, 2007 right bastard those bushes. I just had a quote from toyota aswell and homer is pretty mcuh right they come close to a grand. Toyota UK? Even Steve manley charges £1700 for the full kit - those prices were from Nic Link to comment Share on other sites More sharing options...
Guest mk47 Posted May 24, 2007 Share Posted May 24, 2007 Toyota UK? Even Steve manley charges £1700 for the full kit - those prices were from Nic It was from toyota in coventry. they quoted me for control arms, and a few other bits i cant remember. maybe not the full kit then, bloody useless. i ordered uk spec brake pins and they sent me out caliper bolts for jspec! Link to comment Share on other sites More sharing options...
Nic Posted May 24, 2007 Share Posted May 24, 2007 There are a lot of parts that make up the front and rear suspension and as Homer said Toyota only sell the complete arms, they do not supply replacement bushes. Just changing the bushes, you will see some benefit, but as Homer says you will still have worn ball joints. The ball joints are an integral part of the arms and cannot be replaced separately. I replaced all the suspension components on the front and rear of mine a few years ago, not a cheap job, but the best money I have ever spent on my car, it absolutely transformed the ride and handling. I've attached the EPC images and some pics of the suspension components for reference. Link to comment Share on other sites More sharing options...
colsoop Posted May 24, 2007 Share Posted May 24, 2007 I had poly bushes fitted last year for the front and rear control arms, they are too harsh for me, also after fitting them i found the handling to be worse as it higlighted weaknesses in other areas of the suspension, buy the arms and diff bushes, it will be cheaper (assuming you plan on keeping the car for a while) Wheel hop is still present as well ! By the way are those mine in the picture Nic (fingers crossed) Link to comment Share on other sites More sharing options...
miko_supra Posted January 18, 2008 Share Posted January 18, 2008 how much for just the rear oem suspension parts? (yes i know its an old thread:)) im getting really bad wheel tramping when the second turbo kicks in. Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 18, 2008 Share Posted January 18, 2008 Have you converted the diff mount to dual bushes, al la TT? Link to comment Share on other sites More sharing options...
miko_supra Posted January 18, 2008 Share Posted January 18, 2008 Have you converted the diff mount to dual bushes, al la TT? please explain?... Link to comment Share on other sites More sharing options...
danny_silva Posted January 18, 2008 Share Posted January 18, 2008 rear diff mount on a tt have 2 round shape ruber bushes, and n/a car have only 1.... have a look at yours at the end and you can see... Link to comment Share on other sites More sharing options...
