auto tt rad
hadyn
Try Envy. They sorted me out an OEM rad. You know it'll fit, you won't need any extra coolers and you get some natty draught excluder attached.
I bought new for the simple reason that you never know how long a used bit of kit will last. It'll save money in the long run.
were you losing a lot of coolant paul? any rise in the temp gauge?is the crack easily visible?
yes i was losing quite abit and had to top it up daily, there was no rise in the temp and the crack was easily visible at the front of the rad
are you losing alot of coolant if so check all around the top of your rad and check all the rad pipes has i had to replace one has it started to split
