Does my car need cats for an MOT
cookci
Go to your MOT testing station, ask them to put your car details into their database, and that will tell them wether it requires the stricter cat test or not. All depends on wether VOSA has the correct engine data for the import MK4, as they can't use the UK data, as the import has no EGR.
If you need the stricter test, then either cat should do, but it's easier to change the bigger one (rear)
As Luxo said, Some Supras do not need a cat, when its put into the VOSA database... For instance my car is a 95 NA, I have a bit of paper in the car from VOSA saying no cat required! it has one but i dont need it to pass the MOT! Result ide say... Get your codes checked :)
I'm a tester, All N/A's don't need cats as the 2JZ-GE engine is not on he database as it was never made in the UK, but all TT's wether JAP or UK need a cat as they both have the GTE engine code..
To be honest, there is nothing in the manual saying that you NEED cats, its just a case that it won't go through the 0.2/0.3 CO emissions limits.
Hope that helps..
Hope that helps..
So, what difference will it make to power on an n/a with no cats>??
