kieren1234 Posted May 23, 2007 Share Posted May 23, 2007 Will 440 injectors off a TT fit an N/A????? Link to comment Share on other sites More sharing options...
SupraPL Posted May 23, 2007 Share Posted May 23, 2007 AFAIK: no. Link to comment Share on other sites More sharing options...
kieren1234 Posted May 23, 2007 Author Share Posted May 23, 2007 Cheers, does anyone know for definate???? Its for na-t conversion. Thanks Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 23, 2007 Share Posted May 23, 2007 Cheers, does anyone know for definate???? Its for na-t conversion. Thanks Give Turbofit a call they will tell you, they have done a few of these 01908614971 Link to comment Share on other sites More sharing options...
SupraPL Posted May 23, 2007 Share Posted May 23, 2007 You can buy Boost Logic 440cc or 525cc (i bought those, will fit stock fuel rail) injectors + injector piggy tails from MVP. Link to comment Share on other sites More sharing options...
michael Posted May 23, 2007 Share Posted May 23, 2007 Will 440 injectors off a TT fit an N/A????? NA injectors are top feed, TT injectors are side feed. I believe you can use the 440cc MK3 Turbo injectors but you'll have to use a resistor pack. Link to comment Share on other sites More sharing options...
JustGav Posted May 23, 2007 Share Posted May 23, 2007 It DEFINITELY won't fit, the TT rail is completely different... trust me... Link to comment Share on other sites More sharing options...
kieren1234 Posted May 23, 2007 Author Share Posted May 23, 2007 Ok thanks for the replies. What if i have the TT fuel rail with fpr and injectors??? Link to comment Share on other sites More sharing options...
SupraPL Posted May 23, 2007 Share Posted May 23, 2007 I believe you can use the 440cc MK3 Turbo injectors but you'll have to use a resistor pack. Yes, you can use those injectors. Link to comment Share on other sites More sharing options...
JustGav Posted May 23, 2007 Share Posted May 23, 2007 It DEFINITELY won't fit, the TT rail is completely different... trust me... Ok thanks for the replies. What if i have the TT fuel rail with fpr and injectors??? Different fitment, it is possible I suppose (well anything is possible) to adjust it to fit, HOWEVER it really isn't worth the effort especially with a fuel rail.. Link to comment Share on other sites More sharing options...
kieren1234 Posted May 23, 2007 Author Share Posted May 23, 2007 Thats ok then, i may just go for the mk3 turbo ones, how much would these be, direct fitment??? Link to comment Share on other sites More sharing options...
Nic Posted May 23, 2007 Share Posted May 23, 2007 Thats ok then, i may just go for the mk3 turbo ones, how much would these be, direct fitment??? I can check the price of a new set if needed Kieren Link to comment Share on other sites More sharing options...
kieren1234 Posted May 23, 2007 Author Share Posted May 23, 2007 Yes please mate. If you dont mind. Providing i definately need a set as only planning on running 7 psi for now. So standard injectors on my n/a may be sufficient. Link to comment Share on other sites More sharing options...
SupraPL Posted May 23, 2007 Share Posted May 23, 2007 Nic: Link to comment Share on other sites More sharing options...
