tooquicktostop Posted May 22, 2007 Share Posted May 22, 2007 I need a pressure gauge for my NX Nos system ASAP, anyone ?? Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 22, 2007 Author Share Posted May 22, 2007 Found one Link to comment Share on other sites More sharing options...
Guest Rays the roof Posted May 23, 2007 Share Posted May 23, 2007 Found one Hi mate. Where did you find it and how much. Wizard want £38 for one. cheers Ray Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 23, 2007 Author Share Posted May 23, 2007 PM sent Link to comment Share on other sites More sharing options...
JustGav Posted May 23, 2007 Share Posted May 23, 2007 I didn't think you could tell the pressure of the nitrous. Bear in mind nitrous is injected as a liquid and the bottle has a straw. The pressure gauge will simply tell you what the pressure is of the gas head in the bottle which won't change much until the bottle is empty... Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 23, 2007 Author Share Posted May 23, 2007 I didn't think you could tell the pressure of the nitrous. Bear in mind nitrous is injected as a liquid and the bottle has a straw. The pressure gauge will simply tell you what the pressure is of the gas head in the bottle which won't change much until the bottle is empty... It changes with the temp of the bottle and should be 900 psi for optimum delivery, this also will give you an indication of the volume of gas in the bottle so I dont press the button when it is empty Link to comment Share on other sites More sharing options...
JustGav Posted May 23, 2007 Share Posted May 23, 2007 Okay, I see what you saying... It won't be dead accurate as a 'how full' gauge but it will give you a good idea... The best way to check a NOS bottle is with a set of scales... Link to comment Share on other sites More sharing options...
