DVD player help required.
RedM
DVD: Toshiba sd220e
TV: Toshiba 32zd26p
Supra (yes, really!) component cables
DVD player was working fine a few hours ago but now we get only sound. No picture at all. Plugs are all secure and TV set to EXT4 for component video. Cannot get DVD set-up menu but can get TV set-up menu on EXT4.
DVD player works fine though SCART though!
Assuming some failure with the component video how can I tell if it is the DVD or TV at fault?
Any ideas?
My Toshiba dvd played up so I bought a new one and put it in the loft. That was two years ago. A couple of weekends ago I took it out to try with a view to throwing it, and it worked!!
So my advice to fix your problem is put it in the loft for a couple of years.
We don't have a loft. Will a cupboard work just as well?
Well? ;)
It didn't work. I expected it really as it wasn't an IT problem.:p
Problem fixed.
It turned out that the DVD output setting had been switched from Video (outputting though Component Video) to RGB (for use with SCART). This caused the lack of picture.
The odd thing is that to do this requires several button pushes in the correct order. Deviate just once and nothing gets changed! So, between it being a-okay and then not there was a seven button combo keyed in on the handset!
