New Exhaust...lost horses...
sipstrassi
Hi just aquick question.
I Have a N/A just take 2nd decat out and put in new RSR exhaust. (have the baffle in - very noisy without))
The car seems to have lost some horses and does not pull as well as it did.
How can i get the power back - put in second decat, take out baffle (risk getting stopped by police)
Thanks in advance
Pete
N/A's, particularly modern N/A engines, rely on a tuned resonant length of both intake and exhaust to pull torque up at desired points. Going to a massively big bore exhaust is like radically shortening it. Fiddling with stock air box and fitting an HKS "filter" et cetera alters the tuned length of the induction system. Back pressure, or lack of it, is NOT the reason torque peak areas move about!
I thought it was mroe to do with the exhaust backpressure giving the intake charge something to work agaist even thought the exhaust valve was open (i.e. it wasn't all just blowing through).
Its possibly got more to do with exhaust header and secondary pipe tuning that total exhaust backpressure.
Yeah, okay, I see my error of explanation...
By changing the exhaust to a bigger bore, it would change the resonance frequency (causing the engine to breathe via the exhaust at a different time/frequency), this is required in order to time the waves at the same time the exhaust ports open, so not only does the engine push the combusted material out, but the resonance frequency would set up a wave, if timed correctly the removal wave will help pull the air out of the exhaust ports.. I assume then the intake is the opposite, utilizing the push wave at the correct time to further push in more air into the chamber. On the opposite side, the wave would also help keep the fresh air in the chamber while the exhaust valve closes.
My thinking/explanation more correct now?
Please correct if I am wrong, but by putting in a free flowing exhaust you don't 'loose' the horses as such, however the engine dynamics have changed and by being more breathable the powerband moves up the rev range a tad.
When I fitted the HKS Superdragger to my NA with both cats still in, it felt like I lost power at the lower end of the rev range and gained a little at the higher end so would agree with this. Getting fed up of the noise though so thinking about going back to stock.
Eloquent and accurate :)
You also have to consider that fitting a larger bore exhaust will also cause the exhaust charge to cool quicker, which in effect will slow the gas escape further, which will sap power,which is why you see manifolds etc lagged to keep the gas temps high, its all a question of balance and dynamics
Yup, and with more air getting sucked into the chamber means that older carb engines could run leaner, resulting in burnt valves I understand.
