Guest supraaero Posted May 21, 2007 Share Posted May 21, 2007 Hello all, i have just got my aero supra from japan (na at the moment) but it has a problem when it's idling, it tends to rev its self once its up to running temperature but only between 800 & 1100 rpm, its almost like a pulse type of rythem. Any ideas? Thanks, Marc. Link to comment Share on other sites More sharing options...
dibbleyuk Posted May 21, 2007 Share Posted May 21, 2007 Welcome to the club mate. Im sure someone can give you some advice with your problem. Mine seems to tick over really low onces its been driven hard. I cleaned to TPS sensor on the inlet manifold and it stop it that mite be worth a try.. Link to comment Share on other sites More sharing options...
Al Massey Posted May 21, 2007 Share Posted May 21, 2007 its hunting,there could be induction problem or maybe a spark problem,it may just need a good service and clean Link to comment Share on other sites More sharing options...
Guest supraaero Posted May 21, 2007 Share Posted May 21, 2007 Thanks for the advice i will have a play with it this weekend. Do you know of any events happening soon as i want to get out there & meet you lot asap? Marc. Link to comment Share on other sites More sharing options...
Guest supraaero Posted May 21, 2007 Share Posted May 21, 2007 it had full service just before it got shipped over & i've changed the panel filter for an induction kit so i will try the plugs next. Thanks for your help. Marc Link to comment Share on other sites More sharing options...
Al Massey Posted May 21, 2007 Share Posted May 21, 2007 if you have changed the filter check the air sensor,this could be dirty or not connected that will def cause hunting Link to comment Share on other sites More sharing options...
Guest supraaero Posted May 21, 2007 Share Posted May 21, 2007 Cheers:) Link to comment Share on other sites More sharing options...
Wayney Posted May 21, 2007 Share Posted May 21, 2007 Hello welcome to the club Link to comment Share on other sites More sharing options...
RobSheffield Posted May 21, 2007 Share Posted May 21, 2007 Welcome Link to comment Share on other sites More sharing options...
Guigsy Posted May 21, 2007 Share Posted May 21, 2007 mine idles between real low and about 1000 then drops back down again then raises again,... repeat. But the car has been serviced and mot'd fine in the last few months. Its an NA 2. My clio did it 2. i dont think its a problem Link to comment Share on other sites More sharing options...
