djskeme Posted May 21, 2007 Share Posted May 21, 2007 Hi all, I run a car pc system in my supra twin turbo, and I was just wondering if there is a ODB2 port in this car, and where I would find a cable for this application if there is one as the pc will be a lot more flash if it can show an electronic boost reading, rpm etc. Thanks Ian Link to comment Share on other sites More sharing options...
Jake Posted May 21, 2007 Share Posted May 21, 2007 What Supra do you have? The VVTi Supes have a non-standard ODBII port but the earlier ones are ODBI Link to comment Share on other sites More sharing options...
JustGav Posted May 21, 2007 Share Posted May 21, 2007 There really is no easy way of doing this. The OBDII as you get on the later supra's is also non standard as Jake has said.. In order to extract this you need a different OBDII system. If you are thinking of linking it into a carpc, be prepared for a bit of work, the off the shelf systems do not integrate cleanly from what I have seen so far. Link to comment Share on other sites More sharing options...
