DamanC Posted May 20, 2007 Share Posted May 20, 2007 In the last month or two my walbro uk fuel pump im sure has started to make itself known a little more. It seems to have developed a whine which i have picked up on when getting home and waiting a couple of minuites for the car to cool down. Its always been noticable as walbros are a little more noisey than stock. My AFR's seem fine and im not getting any missing or anything different to the norm, so my question is........is this normal? I suspect the answer will be what i think your going to say My description was proably crap so i took a little video for your attention (turn your speekers up) PS Sorry its on a mobile as the bbc were not available at such short notice HPFkT7I4ZbA Link to comment Share on other sites More sharing options...
Homer Posted May 21, 2007 Share Posted May 21, 2007 That doesn't sound normal. Mine whines a fair amount on a really hot day (25deg+) and been booting it or sat in traffic, but is pretty quiet this time of year. Link to comment Share on other sites More sharing options...
Jake Posted May 21, 2007 Share Posted May 21, 2007 No, that doesn't sound right. I think I'd change it to be on the safe side. Link to comment Share on other sites More sharing options...
b_have Posted May 21, 2007 Share Posted May 21, 2007 Change the sock filter (mine did that a few years ago, change it regularly now) Link to comment Share on other sites More sharing options...
DamanC Posted May 21, 2007 Author Share Posted May 21, 2007 Sorry, sock filter? The filter attached to the fuel pump i presume? Otherwise ill replace it, althou its only about 8 months old. Link to comment Share on other sites More sharing options...
DamanC Posted May 22, 2007 Author Share Posted May 22, 2007 Link to comment Share on other sites More sharing options...
DamanC Posted May 23, 2007 Author Share Posted May 23, 2007 Kerplunk. Link to comment Share on other sites More sharing options...
Jake Posted May 23, 2007 Share Posted May 23, 2007 Yes, he means the filter attached to the pump (if that's why you're bumping this thread?) Link to comment Share on other sites More sharing options...
DamanC Posted May 23, 2007 Author Share Posted May 23, 2007 Thanks Jake, that was what i was after Link to comment Share on other sites More sharing options...
Jake Posted May 23, 2007 Share Posted May 23, 2007 Of course there's an easy way to check Charlie's idea, Daman, just take the sock filter off. For testing purposes I mean. You have the stock in-line fuel filter anyway and you'll be able to see if there's much shit in the tank when you take the pump out. Link to comment Share on other sites More sharing options...
b_have Posted May 23, 2007 Share Posted May 23, 2007 Of course there's an easy way to check Charlie's idea, Daman, just take the sock filter off. For testing purposes I mean. You have the stock in-line fuel filter anyway and you'll be able to see if there's much shit in the tank when you take the pump out. That would do it, also when I changed mine, I took the opertunity to clean the tank (lots of debri in the swirl pot) Sorry Damon, thought you were bumping for other opinions) Link to comment Share on other sites More sharing options...
DamanC Posted May 23, 2007 Author Share Posted May 23, 2007 Nope, your sugestion is number one on my list Charlie Can i ask if you are replacing with Walbro Sock filters (if so where on earth are you getting them from) Or toyota ones? How are you cleaning out the fuel tank? Its a very dark smelly place in there Link to comment Share on other sites More sharing options...
DamanC Posted May 24, 2007 Author Share Posted May 24, 2007 Sorry guys, im still at a loose end here Link to comment Share on other sites More sharing options...
Marty Posted May 24, 2007 Share Posted May 24, 2007 My missus has developed a whine too, does that mean she needs changing ??? (plese say yes ... ) sorry my post is of no use to the tread Link to comment Share on other sites More sharing options...
b_have Posted May 24, 2007 Share Posted May 24, 2007 Nope, your sugestion is number one on my list Charlie Can i ask if you are replacing with Walbro Sock filters (if so where on earth are you getting them from) Or toyota ones? How are you cleaning out the fuel tank? Its a very dark smelly place in there I sourced my Walbro ones from Powerstation (oem are different fitment) To clean the tank, I syphoned it with a pump and then just mopped it with blue roll. Link to comment Share on other sites More sharing options...
DamanC Posted May 24, 2007 Author Share Posted May 24, 2007 Ok thanks Charlie Link to comment Share on other sites More sharing options...
