Engine bay covers
colsoop
  • Replies 166
which of these will fit the N/a?
1. Rad cover curved - £17
2. Fan shroud cover.- £45
3. Rad cover straight.- £18
4. Fuse box covers (vented)£40
4a.Fuse box covers (plain)£37
either of the above
6. Brake reservoir covers £15
7. Power steering & brake caps £25 per pair
8. Small relay covers (tt only) £15
9. Washer fluid caps £11
Hi
Can i have one of everthing please.
Yes you can, vented or plain fuse cover ?
The duct that sits on top of the rad can't be used with the fan shroud cover.
Sorry still a bit new, does this mean that this does not fit with the standard airbox? - if so please change my order to(if not ignore me)
4a
5
6
8
9
How about the battery cover, can you supply them???????????
I don't make them in batches due to different sized batteries that we have fitted.
However if you want one i could get one made up for you if you give me the dimensions of you battery, it wont be till after this order has beenmade though.
Here there. Im interested in:-
5. Ignitor covers (tt only)£11
But could you tell me what the difference is between 4 and 4a? (vented and plain)
Thanks,
Chris.
Hi Chris
The difference is just the top of the fuse cover has vents added for a contrasting look (see linked image)
http://homepage.ntlworld.com/colin.lewarn/Metal%20Polishing%20site/images/fusecover.jpg
4a
5
6
8
9
Hi there, it fits fine with the standard airbox, but the top air feed to the airbox will no longer fit.
Parts available and prices will be:
p.s. you're a really bad man, with all that under the bonnet :cool: I'm going to have to not open it around the missus, or she'll realise why our wedding funds aren't growing as quick as they should...:innocent:
will also take some rad clamps if you have them
Size of cover to fit battery is, I have no idea how to do a lined drawing, its 230mm across bottom 175mm up then cut out of 50mm in 70mm high, then 130mm across top in middle. Not sure if that sounds okay. Did a lined drawing in paint but can't upload file:d
hi there is this a one off buy or are they going to be ready for a while as i want them all but can afford to buy all at once. cheers mark
After this one i will get another batch to keep in stock so no worries about timings :)
if i pay you at the end of the month can you post it out then?
Im not sure they will be done by then Jazz, i would prefer to take any money once i have the parts in my hands just in case of delays that way only i lose out.
I could do with some bling, I'll have:-
4a.Fuse box cover (plain)£37
5. Ignitor cover (tt only)£11
6. Brake reservoir cover £15
8. Small relay cover (tt only) £15
9. Washer fluid cap £11
Cheers!
either of the above
You say #8 will fit the N/A but it says only tt after it ????? i'm confused .... lol
