removing the pads from a brembo caliper????
johnd-mkiv
You have the evo (6,7,8) brembo calipers if I'm not mistaken..
if so from memory i'm sure the 2 pins just tap out, as on one end of each pin there is a split olive which acts as a spring when you tap them in...:)
cheers Jon
