tooquicktostop Posted May 20, 2007 Share Posted May 20, 2007 I got back late last night and this morning noticed a damp patch under the car, on inspection the plastic blanking cap?? on the water pump has a split and when hot sprinkles water everywhere! Where can I get one of these today does anyone local have one, beer tokens available ! I am in Essex near dartford crossing Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 20, 2007 Author Share Posted May 20, 2007 OK i have taken a couple of pics to show where the leak is, I have wrapped some tape around the split cap in an effort to stem the flow! is this plastic cap a Toyota part? Link to comment Share on other sites More sharing options...
Graham S Posted May 20, 2007 Share Posted May 20, 2007 I think a quick fix for the moment mate would be to go to a motor factors and get some hose that'll fit on the pump and get a bolt the same size and shove it in the end with a jubilee clip to hold it tight till you can get the proper part? Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 20, 2007 Author Share Posted May 20, 2007 I think a quick fix for the moment mate would be to go to a motor factors and get some hose that'll fit on the pump and get a bolt the same size and shove it in the end with a jubilee clip to hold it tight till you can get the proper part? Cheers sounds like I could manage that Link to comment Share on other sites More sharing options...
terribleturner Posted May 20, 2007 Share Posted May 20, 2007 Yeah it's just your water feed for the stock turbo's. When you went single it just would have been blocked off. Mine had just some stock hose with a bolt in and 2 jubilee clips and will work fine. Link to comment Share on other sites More sharing options...
