dandan Posted September 10, 2004 Share Posted September 10, 2004 Hi all, Can anyone give me any info on the traction control butterfly removal kits that are available for the mkiv (non vvti)? ARe they the same for jdm/uk throttle bodies? Also, can the ecu next to the main ecu simply be disconnected? What happens if I do nothing else other than unplug this ecu (ie leave butterfly and motor etc in place? - I need a bit of space in that footwell! Quote Link to comment Share on other sites More sharing options...
Grazer Posted September 10, 2004 Share Posted September 10, 2004 After I installed my RLTC I unlugged it, removed it, accidentally ran over it then threw it in the bin Quote Link to comment Share on other sites More sharing options...
dandan Posted September 10, 2004 Author Share Posted September 10, 2004 Cheers Grazer... You did nothing with the wiring or anything else? Just unplugged the ecu that has something like "Electronic Throttle Control" on it? No ill effects like fault codes or flashing lights etc? Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted September 10, 2004 Share Posted September 10, 2004 My traction ECU is in the loft, with the butterfly bit still in place. But the butterfly is going in the loft aswell soon. Hopefully the space from the ECU will be big enough for the emanage to fit in! Ben.. Quote Link to comment Share on other sites More sharing options...
Grazer Posted September 10, 2004 Share Posted September 10, 2004 Yep - just unplugged it and binned it Plenty of room for RLTC unit: http://homepage.ntlworld.com/gcsimpson/2004_08_rewiring02_resize.JPG Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 10, 2004 Share Posted September 10, 2004 Yep, must agree with the others comments, no ill effects caused by unplugging the throttle ecu on a manual. On an auto, I believe you may lose the gear change smoothing effect caused by the sub throttle butterfly closing slightly. Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 10, 2004 Share Posted September 10, 2004 Garage shelf for my unit Even better, the Slip Cont light doesn't flash so I didn't have to take the bulb out. Loads of room for the fields harness now Glad to see someone else uses choccy block connectors lol. I'm upgrading mine to proper connectors from vehicle wiring products, but I'll have a diagnostics tap off them leading to a choccy block. With my track record on electrics these are essential... -Ian Quote Link to comment Share on other sites More sharing options...
Grazer Posted September 10, 2004 Share Posted September 10, 2004 Originally posted by Ian C Glad to see someone else uses choccy block connectors lol. Me and burning pokers with molten metal near expensive things is not a good mix Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 10, 2004 Share Posted September 10, 2004 Originally posted by Grazer Me and burning pokers with molten metal near expensive things is not a good mix And you thing thin strands of copper being screwed, twisted, crushed and torn by a lump of metal is better? Quote Link to comment Share on other sites More sharing options...
Grazer Posted September 10, 2004 Share Posted September 10, 2004 For you - no For me - probably Once I learn to solder properly I'll redo it Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 10, 2004 Share Posted September 10, 2004 LOL, I was only pulling your leg mate Quote Link to comment Share on other sites More sharing options...
Grazer Posted September 10, 2004 Share Posted September 10, 2004 Originally posted by Matt Harwood LOL, I was only pulling your leg mate lol - I fitted it last year and i've been waiting for someone to say "what fool would do that" all that time I'm not paranoid - they are all actually out to get me. No really Quote Link to comment Share on other sites More sharing options...
