TEIN Adjustables
Need4Speed
CJ - It's a four page article using an Impreza set up by Graham Goode Racing. The final sentence "So, as an easily tweakable track and road-friendly suspension kit that can be fine tuned to your preferences at the touch of a button, it's got to be worth considering".
I like the appeal of being able to use 2.25" springs, with adjustable ride-height and preload as well as the EDFC system. They will need a fair amount of work to set-up from scratch.
I did see it and had forgotten about it.
OK, to my mind, the system is super duper. I love the fact that i can change the ride dampers to suit both my mood of driving and the surfaces. It is very simple to use and the tein suspension has been very good.
I am not sure if you are aware but the EDFC can only control the dampening and not ride height from inside the car. The height still has to be adjusted via spaner outside.
HTH
