Air con
Franky
Hi, new here, hoping someone has an easy answer :)
On a trip today, air con was working fine, but at some point i noticed all the button lights for it had gone out and after twiddling i was a bit stressed to find that the air con wasnt working at all.
Everything else in the car seems ok, just no air con, fan etc.
Can anyone point me in the right direction please ?
Cheers,
Franky
Guest Martin F
Sounds like somebody has had the dash out and at some time dislodged the connections to either the A\C panel or maybe the A\C amplifier.
Hopefully this is all it is and you can just remove the dash panels and plug things back in. If not then you need to start checking fuses.
