Tricky-Ricky Posted May 14, 2007 Share Posted May 14, 2007 if hes rubbed it with g3 ric clay wont touch it Thats what i thought, the dust/tree sap like stuff is raised but wont move, the water mark effect can ever so slightly be felt in some areas, are the plain blacks lacquered? would be a bit of a cock up if it was under the lacquer, unless its something that has occurred over time, but i have never seen it before, and no its not been re sprayed. Quote Link to comment Share on other sites More sharing options...
peter richards Posted May 14, 2007 Share Posted May 14, 2007 ok then if its raised , you could try some glue / tar remover , but you have made marks from rubbing with the g3 , so a bigger area now has to be repaired Quote Link to comment Share on other sites More sharing options...
Konrad Posted May 14, 2007 Share Posted May 14, 2007 When I was doing mine, I was using Porter Cable machine and Sonus FX range. FX 1 to remove scratches, then FX 2 for swirl marks and small scratches, FX 3 (ultra fine) to remove holograms and give deep shine. After that I put some Autoglym polish resin to correct small imperfections, then AG glaze as a sealant (looks scary when drying ) and after that Meguiars Caranuba Wax. It take a LOT of time if you want to do it properly, also mind it was my car, my first polishing using PC, so i took my time. Sonus cosmetics are nice, very oily - so do not leave too much dust and give nice shine, but i'm tempted to try Menzerna range on my gf Supra and finish it with Chemical Boys wet look sealant. Oh well, I will toy with this idea and gather proper stuff till summer, when Jola's Aerotop will finally get back to english soil Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 14, 2007 Share Posted May 14, 2007 ok then if its raised , you could try some glue / tar remover , but you have made marks from rubbing with the g3 , so a bigger area now has to be repaired Had a go with tar remover, same result:( Quote Link to comment Share on other sites More sharing options...
peter richards Posted May 14, 2007 Share Posted May 14, 2007 When I was doing mine, I was using Porter Cable machine and Sonus FX range. FX 1 to remove scratches, then FX 2 for swirl marks and small scratches, FX 3 (ultra fine) to remove holograms and give deep shine. After that I put some Autoglym polish resin to correct small imperfections, then AG glaze as a sealant (looks scary when drying ) and after that Meguiars Caranuba Wax. It take a LOT of time if you want to do it properly, also mind it was my car, my first polishing using PC, so i took my time. Sonus cosmetics are nice, very oily - so do not leave too much dust and give nice shine, but i'm tempted to try Menzerna range on my gf Supra and finish it with Chemical Boys wet look sealant. Oh well, I will toy with this idea and gather proper stuff till summer, when Jola's Aerotop will finally get back to english soil thats the compounds i use menzerna , not sure what to sugest now , its tough when you cant see the problem Quote Link to comment Share on other sites More sharing options...
Konrad Posted May 14, 2007 Share Posted May 14, 2007 thats the compounds i use menzerna , not sure what to sugest now , its tough when you cant see the problem Her car is is in OK condition, I expect swirl marks, maybe few small scratches. Colour is dark blue, that's why I want to test Chemical Boys stuff to make Aerotop really really shiny. Which Menzerna you would advice for swirls, little scratches, spider webs Peter? I can do with 2 stages so fine and ultra fine will be ok. I just got lost with all Menzerna numbers Quote Link to comment Share on other sites More sharing options...
peter richards Posted May 14, 2007 Share Posted May 14, 2007 im going to start with 106 tomorrow on the impreza , see what it will take out , if no good just keep going up , but it has a slide scale on the side , showing cut strengths , i wont be using a cutting pad ill stick with the polishing pads Quote Link to comment Share on other sites More sharing options...
Konrad Posted May 14, 2007 Share Posted May 14, 2007 im going to start with 106 tomorrow on the impreza , see what it will take out , if no good just keep going up , but it has a slide scale on the side , showing cut strengths , i wont be using a cutting pad ill stick with the polishing pads Do not forget to drop word or two here, when you will finish and maybe pics before and after Quote Link to comment Share on other sites More sharing options...
peter richards Posted May 14, 2007 Share Posted May 14, 2007 yes , but the forecast is el crappo for the morning , but i have got a garage to work in , jobs a 130 mile round trip Quote Link to comment Share on other sites More sharing options...
colsoop Posted May 15, 2007 Share Posted May 15, 2007 I use menzerna when Tim has it in stock I did my fiat seicento 2 weeks ago i had to use an sfx 1 spot pad and menzerna medium cut, the paintwork was that bad due to the poor valeting job done at the dealers I then followed round with a menzerna final finish on an sfx 2 Followed by klasse all in one on an sfx 3. Followed by klasse sealant glaze with hand applicators. Followed by carnauba wax. Good luck with the Imprezza Peter, i seem to remember the paintwork being quite hard on those cars. Quote Link to comment Share on other sites More sharing options...
gaz1 Posted May 15, 2007 Share Posted May 15, 2007 bugger i just wash mine then a little sonax polish, i could do with a valeter to come to me and do the works, but who:search: harwich is where the car is, but there does not seem to be any around here:( Quote Link to comment Share on other sites More sharing options...
charlton Posted May 15, 2007 Author Share Posted May 15, 2007 anyone got any opinions on what would be best? Quote Link to comment Share on other sites More sharing options...
