**Attention traders: PHR N/A-T kit, clutch, AEM UEGO, decat, discs, fluids WANTED.**
SupraPL
Can you please pm me prices (including VAT and p&p) for:
1. PHR Stage 1 Single Turbo System (N/A-T kit)
2. RPS Max Clutch with Street Disc for Supra non-turbo
3. AEM Gauge-Type UEGO Kit w/AFR Sensor
4. 1st and 2nd decat pipes with resonator/silencer for Supra non-turbo
5. OEM UK TT discs (full set)
6. TRD/Motul/Castrol SFR brake fluid
7. Best quality engine oil, gear oil and coolant
EDIT:
8. Injectors: Boost Logic 525CC Injectors x 6 (fits in the stock rail) + Injector Piggy Tails x 6
9. Proper headgasket (Boost Logic 2.5mm Head Gasket?)
10. Good quality head studs (ARP)
EDIT: Can i get price for Boost Logic Stage 2 NA-Turbo Kit as well, please?
Thanks in advance.
Tomasz
Sure - please find my prices below:
1. £2500
2. £340
3. £235
4. £115 for 2nd de-cat, you won't need the 1st.
5. £330 - Toyota OEM
6. £18 - Motul 5.1
8. £60 - 8 Litres Valvoline VR1 5w50
£48 - 4 litres of Motul Gear 300 (Gearbox & Diff)
£36 - 10 litres of Toyota OEM Cool Red
Gaz.
1. £2500
Gaz.
1. If the price include vat and p&p that's cheap!!! :respekt:
4. I want full decat and decat-pipes must have silncer or resistor. ;)
1. £2500
2. £340
3. £235
6. £18 - Motul 5.1
Gaz.
Thanks.
It is just a part of my shopping list... ;) The rest parts will supply Nic and my mate from Poland. :)
Am busy hiding these figures from Scooby.:D 3.5k + and the list goes on. Fair play to you Sir... :)
No probs :)
The PHR NA-T kit downpipe will mate up to the 2nd de-cat - there will be no first cat pipe (that is how the single kits work anyway).
When you say silencer, you wouldn't put that in a de-cat, you would put that in an exhaust. What exhaust do you have?
Gaz.
No probs :)
Gaz.
HKS Hyper Titanium - it's very loud exhaust after decat. I have seen somewhere 2nd decat pipe with resonator, but i can't find it now :(
Can you not keep the baffle in when you need it quiet and take it out when you want it loud? :D
Gaz.
Gaz.
I have got baffle but i don't like to use it ;) I need decat with silencer :)
Could you also give me prices for:
8. Injectors (no idea what size [440-540cc], my goal is 400bhp, peak boost 1.0 bar, non turbo fuel rail)
9. "Proper" headgasket
Thanks
Tomasz
Thanks
Tomasz
8. Those injectors are a pain. And expensive (£700 last time I priced them) Best of converting to a UK Supra fuel system IMHO.
9. £300 (PHR, if bought at the same time as the NA-T kit)
10. £115 (ARP)
How much for conversion? What parts do i need?
Can i fit injectors from Supra MK3 TT?
Thanks
Tomasz
EDIT: What are you think about:
http://www.powerhouseracing.com/files/catalog.php?make=Toyota&model=Supra%20NA&catagory=Fuel%20System%20Upgrades
EDIT2: Maybe Boostlogic 2.5mm headgasket will be better as this will reduce compression to 8.5:1 (same as a tt)
http://www.boostlogic.com/xcart/product.php?productid=81&cat=15&page=1
Erm, that I would have to price UK - what I ideally meant was it would be cheap to buy a second hand/used fuel system from someone upgrading.
PHR injectors (they've come down a bit) would be £475 in that case.
The BL headgasket you would have to get from TerryS as he's the distributor.
Gaz.
Thanks
Tomasz
...Seeing ENVY are already working on the items for you, happy to say you should buy the parts from them as the prices are reasonable.
Cheers
Andy
Yeah again as Andy says i would be hard pushed to do much better on the pricing, plus gaz is too nice to start undercutting:p .
That's right guys. The prices are quite good :thumbs: , but maybe MVP Motorsports can beat down the price ;)
Gaz: If i place a large order, are you able to do some extra discount for me?
Its a possibility but those prices are cut to the bone for what you wanted.
Drop me a PM when your ready to order and we'll go from there :)
Gaz.
