blitz nur spec
suprarob
  • Replies 50
Posted Images
Guest Martin F
Just by changing the cat-back exhaust section you will gain some power but only a small amount, estimate 6-9BHP.
The best thing to do is to get a cat replacement pipe and get rid of those damned cat's...... :D
Good choice on exhaust though, the Blitz Nur Spec is a lovely exhaust and very well made.
Damn somebodies nicked me old avatar, didn't even get chance to select it........
:baa:
Originally posted by suprarob
Sorry I nicked your avatar, you can have it back if you like?
I thought if Iremoved both cats the supra would fail the MOT
how much power gain just removing one?:) :devil:
If you remove the cats you will fail the MOT
To pass the MOT by putting them back on for that day...warm them up and job done...if your car is between 93 and 95 and is J-spec then the MOT station COULD pass it without putting the cats back in.
If you take out the 1st cat (most restrictive) 40hp inc the cat back exhaust.
Take out both 60-80hp.
You've reached the max for j-spec fueling.
If your's is UK spec then your a luck lucky man!
Guest Martin F
No problem about the avatar, my mate Arnold is helping me out. :)
If you remove both CAT's chances are your car will defenitely fail the MOT, but hey the MOT only comes once a year ;)
I notice you have a UK spec so you would have no over-boost problems if you remove both CAT's. Defenitely the way to go. The CAT's are the biggest restriction in the whole exhaust system and also contribute a lot of heat to the turbo area.
Chris Wilson produces CAT removal pipes and i think they are £150 each, so for both you would be looking at £300 investment for approx 25 - 30 BHP increase.
If you do the whole lot in one go, including Nur-spec, i guess you can expect an increase of between 35 - 40BHP. But the sound will be gorgeous and one of the biggest benefits will be the turbo's will spool quicker.
Go on, you know it makes sense.
:thumbs:
Guest Martin F
60 - 80hp increase for removing cats and replacing exhaust ?
So a UK spec would reach 400BHp ? I think you've been reading too many of those American sites Alex.
:D
:thumbs:
Damn it Martin, stop being so conservative!!
Rob if you fit a Flux Capacitor you'll really make some power!!! ;)
Guest Martin F
OK i'll crack open a few beers!
:cool:
I removed the cat on my cavalier turbo it was a K plate and had to have the cat test at the MOT got fed up with putting it back on every year............
BUT.......
MOT man told me that if they cant read the engine number to identify it to the computer, they dont know what test it should have, so they run a non cat test.
Personally I dont know if the supra will pass a non cat test, It should do.
He told me they also have to run the non cat test on series 1 mondeos, something to do with 95% of them wouldnt pass the cat test even with a new cat!
I put my UK-spec through MOT with no cats and it *just* failed due to emissions. was marginal though.
and you only need to put ONE cat back on to get it through. If you have a "nice" MOT man then you could always explain that you could put the cat back on, but it'll be coming straight back off again afterwards and see what he says....
UK-specs are fine with no cats - no overboost problems at all. you will need a TRL Performance UFCC fitted to allow the car to boost higher than 14psi-ish. Just taking the cats off or just changing the exhaust won't have much effect. you really need to do both to get the big benefit.
Originally posted by Adam_SG
How much for this inc fitting..... know anywhere is the Oxford or Midlands that specialises in supras...
Thx:p
Any exhaust centre will fit the parts for £20 or so..20-30 mins job done.
This is Chris Wilson's e-mail address. Drop him a line to enquire about decat pipes.
[email protected]
HI Doughie
this VFCC thing is it some sort of fuel cut and boost controler
if it is how far can you turn the boost up?
If you can adjust the boost using this can you do it with the standard exhaust fitted
or can I do this with a blitz boost controler
once on the road to more power will I be able to stop
is there a clinic for boostaholics ?
:baa: :) :devil:
By removing both cats on a Jspec your will, dependant upon which pipe setup you use, get from 1.2 to 1.4+ without a boost controller. You will not get the boost controller to bring boost back down. Well not much, Alex posted about a slight redicution in levels using his controller and I think Leon cat set them up to get a bit of reduction.
HI Doughie
:baa: :) :devil:
The VFCC raises the level at which the ECU cuts fuel on high boost. It does not raise boost but enables you to raise your boost with a degree of safety and without hitting fuel cut. The new levle is about 18 psi adjustable.
Suprarob
just to add to what Phil said, the VFCC is not a boost controller and won't change the max. boost that your car currently develops.
but it *allows* other performance mods (like free-flow exhaust, de-cat pipe, electronic boost controller, bleed valve) to work but moving the car's "fuel-cut" level higher. Fuel-cut is set at about 14psi on a mkiv supra and if (as stock) the car detects that turbo boost has reached 14psi, (about 0.9bar or so) then it simply cuts all fuel being injected into the engine which feels like a fairly dramatic bang / event. In effect it's a safeguard to stop the car overboosting.
But the mkiv will happily cope with more than 14psi and so installing a £60 VFCC (also known as a fuel-cut defencer / defeater) will raise the level at which fuel-cut happens to about 18psi. you don't want to remove fuel-cut completely. The TRL Performance fuel-cut raises fuel-cut to roughly 18psi or so.
So if you install a boost controller or take the cats off and fit a free-flow exhaust like the Blitz NUR spec then the car WILL hit fuel-cut (not nice) unless you fit a VFCC.
One final thing - Jap-spec MKiv TT tend to give substantially more boost than UK-specs for certain mods like the exhaust / de-cat.
But often they allow too MUCH boost which is defnitely not good.
accepted sensible limit for boost on a mkiv is about 17-18psi.
UK-spec cars have steel-bladed turbos which are a little tougher than the Jap-spec ceramic-bladed turbos which can suffer from what is known as "pottery failure" if too much boost is used. (ask Barry / JB ...)
hope that all makes sense.
Thanks guys
You,ve given me alot to think about
I uped the boost on a gt4 and got fuel cut(not pleasant)
going to need a boost gauge as well and that posers a whole set of new ideas/problems/questions
I think I,ll just go and look at the blitz web sit again.:devil: :)
