someone is comimg to look at my car today
Paul372
Fan belt is a DIY job, fairly easy to do, as to the aircon pump... I would check it you can disconnect the power to the pump, and disengage the clutch on the aircon pump. That way you can avoid paying massive bills replacing the pump itself. Obviously your aircon isnt going to work until you eventually replace the pump, but at least it will get your car back on the road quickly.
