RSR Lowering Springs
swandip
I have recently had RS-R sports springs fitted. Mine are adjustable ride height by the way, not sure what your selection is.
But I can adjust from no ride height.. ie. wheels scrubbing the wheel arch .... and upto a few centimetres above stock ride height.
They are a very stiff spring by the way. More suited to devoted trackday use and racing IMO. Very bumpy on 'B' roads.
Seem to work well on 'A' roads and they definitely control the dynamics of a Supra when cornering I'll give them that !
I'll be giving mine a thorough testing on the Nurburgring in July.
I have RSRs too. They're very low and quite crashy over the bumps. No so good 2-up with a bootfull of Calais booze either (as I found out yesterday).
Hmm - I wonder if they're the adjustable ones? I've never checked...
Aron's setup is actually coilovers rather than springs Ivan so if you've got separate shockers to your RS*R springs then they'll not be adjustable.
Ebaich are a good choice mate, Chris wilson recomends them also.. :D
I wouldn't quite go that far as to say he recommends them, iirc he states that the ride height is still too low when using them.
Adjustable in the sense that you have a number of rings on a screw thread that control the compression of the spring.... (the screw thread is on the shock absorber).
So it is indeed the shocks that would control the spring adjustment but I was trying to differentiate between the bound and rebound control that are usually associated with adjustable shocks.
I use the car daily so ebach sound more user friendly for my needs. How can you have adjustable springs? do you not mean shocks that are adjustable.
