Robbo Posted May 13, 2007 Share Posted May 13, 2007 I need some bolt on spacers 15mm to 20mm for the rear of my supe. Can anyone suggest where I can get them from or has anyone got a set for sale? Thanks Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted May 13, 2007 Share Posted May 13, 2007 I can supply H&R Hub Centric spacers, please call me tommorow for a quote, thanks. Link to comment Share on other sites More sharing options...
Robbo Posted May 13, 2007 Author Share Posted May 13, 2007 I want bolt on's not hubcentric, thanks anyway. Link to comment Share on other sites More sharing options...
jazz1 Posted May 13, 2007 Share Posted May 13, 2007 h&r are the best ones Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted May 13, 2007 Share Posted May 13, 2007 I want bolt on's not hubcentric, thanks anyway. The H&R's are bolt on. Link to comment Share on other sites More sharing options...
ChrisSZ Posted May 13, 2007 Share Posted May 13, 2007 Why bolt-on specifically? Anyway, these guys are the kiddies :) http://www.srbpower.com/hr/spacers.php Link to comment Share on other sites More sharing options...
ChrisSZ Posted May 13, 2007 Share Posted May 13, 2007 PS. If you use bolt-ons for a spacer that's only 15-20mm thick you will need to cut down the original studs and you will have very little material thickness to support the studs in the spacers - personally I'd go for the extended stud option. H&R do either Link to comment Share on other sites More sharing options...
Robbo Posted May 13, 2007 Author Share Posted May 13, 2007 I don't want Hubcentric because I don't want the hassle of splitting the hub and running the risk of fu*king the bearing. Bolt-on's are just less hassle, ok I know I'll have to trim the original stud's down but hey. Link to comment Share on other sites More sharing options...
ChrisSZ Posted May 13, 2007 Share Posted May 13, 2007 I don't want Hubcentric because I don't want the hassle of splitting the hub and running the risk of fu*king the bearing. Now I'm really confused:blink: Hubcentric spacers are simply spacers that are designed to fit perfectly snugly around the raised central part of the hub to keep the wheel perfectly centred - nothing to do with splitting hubs etc:Pling: Like this:- the raised bit matches the shape of the actual hub itself You can see how the hub fits into the exact centre of the spacer thus ensuring it mounts exactly central to the hub Link to comment Share on other sites More sharing options...
Daston Posted May 13, 2007 Share Posted May 13, 2007 if you dont mind cutting the studs down I have 2 spacers that I have just taken off. no idea on the make but they seemed to work fine. Link to comment Share on other sites More sharing options...
Nic Posted May 14, 2007 Share Posted May 14, 2007 Something to read before fitting spacers. http://planetsoarer.com/offset/studs.htm http://planetsoarer.com/offset/offset.htm Link to comment Share on other sites More sharing options...
Robbo Posted May 14, 2007 Author Share Posted May 14, 2007 Thanks for your help guys. The information about the hubcentric spacers was given to my b/f when he was enquiring about a set of spacers to fit to his GTR. I think it was Jap Shop that give him that information. Oh well they are obviously wrong! I will let him read the thread tonight and we will take it from their Link to comment Share on other sites More sharing options...
Robbo Posted May 14, 2007 Author Share Posted May 14, 2007 if you dont mind cutting the studs down I have 2 spacers that I have just taken off. [qimg]http://img.photobucket.com/albums/v232/godaston/DSC00010.jpg[/qimg] no idea on the make but they seemed to work fine. I will let you know tonight Datson, thanks. Link to comment Share on other sites More sharing options...
Daston Posted May 14, 2007 Share Posted May 14, 2007 Oh and if you want I have the cut down studs as well Link to comment Share on other sites More sharing options...
Robbo Posted May 14, 2007 Author Share Posted May 14, 2007 Datson you have PM Link to comment Share on other sites More sharing options...
AndyT Posted May 14, 2007 Share Posted May 14, 2007 Had me worried reading this since just ordered wheels from Envy. No worries though Gaz supplies everything. Good man.. Link to comment Share on other sites More sharing options...
