Why does the Supra have a fuel cut system?
RedM
I've been wondering. We have a fuel cut system on the Supra and we have the means to prevent it.
Why does the ECU cause fuel cuts and does using a FCD mean that we are potentially doing harm to our cars?
People want more power so they fit FCD but at the cost of reduce reliability.
So, I was sort of correct then that fitting a FCD will cause the engine to suffer.
What's the better way to avoid this? Boost controller?
Got to fit a restrictor £15 that limits boost to 1.2 bar thus protecting the engine and turbos etc. Homers BPU faq is ace for this info...:)
the biggest point is... it's a failsafe in case things go wrong (preventing a massive overboost situation)
The Thor one lets you keep the boost cut at a raised limit Martin - definitely worth considering
What would you set it to? 1.25bar? 1.3? How often is 1.2 bar reached in a BPU car?
Or you could down the route of fitting a 1bar RR and using a boost controller to raise the boost, this giving you a little bit more than stock as stock is arounf 0.7-0.8 bar. You will still need the FCD for when you do raise the boost, but at least you still have more control (safeguard) than a 1.2 bar RR. As mentioned above depends if you're turbos and engine will let you go to 1.2 bar.
Upping the boost above stock level will reduce the life of the engines and turbos however you do it.
You would still need an FCD fitted even using a boost controller to raise the boost. An FCD basically fools the signal to the ECU, so it doesn't think the car is going over the stock boost cut and so doesn't cut fuel.
What causes the damage that the ECU and it's fuel cut are seeking to prevent?
I'm assuming that it's just turbo related as big singles run at more than 1.0bar but have aftermarket ECUs too.
Then the you ask, if it doesnt know how much boost its running how does it fuel it correctly :D
One of those things I guess that the search button is your friend. I believe you use one of those Apexi things I can't remember the letters that go after it.
Could well be true as ive recently read the people who have gone single seem to get better mpg?
A restictor ring does limit the boost to a certain extent, it is not a fail safe though and doesn't prevent the turbos from overboosting, if say a pipe was to split or come loose. Boost levels can also vary depending on the temps, ie. in winter the boost may go slightly higher than in the summer.
The better FCD's raise the fuel cut level rather than remove it completely, which means you still have a margin of safety if the car does unexpectly overboost.
Could the whole FCD, restrictor ring, boost controller route be avoided by using an aftermarket ECU that is set up properly?
I'm not sure what is happening to cause the damage that the ECU/FC is seeking to avoid but it does seem that the BPU bits are just a fudge to get more power for minimum expense but with a risk of reduced reliability/longevity.
Which is one of the reasons to stay clear of the HKS FCD as this completely removes it iirc.
The Greddy one is the one to go for since Thor have stopped doing the TRL one.
:respekt: Bows to the wisdom. :) Will be needing you for when I go BPU next year Nic..:)
I'm not sure what is happening to cause the damage that the ECU/FC is seeking to avoif but it does seem that the BPU bits are just a fudge to get more power from minimum expense but with a risk of reduced reliability/longevity.
The aftermarket ECU is an exspensive way of doing it, I asked Rob this and you could probably go full BPU inc decats(not exhaust & smic) than the cost of an ECU.
Or again he could be bored and winding us up since it has been done to death already, unless Mawby has broke the search button. ;)
Aimed at me? I'm just curious to know if there is a reason why everyone follows the BPU route re: parts.
Is there a better way and, if so, why isn't everyone doing that? Is it more expensive? Is it harder to get right?
I've just posted above that BPU seems like a cheap-ish fudge and a fudged job is usually done to keep costs or complexity down.
It would be expensive and really you're never going to get a standalone mapped as well as Toyota have done.
You couldn't stop the turbos overboosting though. A stand-alone ECU can't compensate for the undersized j-spec wastegate.
If this is you're feelings go single then, save up £6k ish iirc for a small single. Job done.
The restrictor ring is needed due to the mechanics of the motor over boosting when there is less restriction in the exhaust, no electronics can prevent/stop it.
A replacement ECU does replace the need for FCD, SLD and boost controller but its an expensive way of doing things.
