Anti Freeze ?
jagman
The reason for my post ; extracting more and more power from the Supra is a favourite topic, yet nothing much is posted on coolant.
more power = more heat
fmic fitting = less cooling
some go to the expense of fitting more efficient aftermarket radiators
but coolant hardly mentioned, PURE water is the best coolant
it has a far better heat transfer rate than anti freeze
straight water is about twice the heat extraction than a 50/50 mix
if you ran pure anti freeze you engine would run hotter!!!!
why do not more people use water wetter in place of anti freeze as a corrosion inhibitor and lubricant for the water pump?
especially this time of year and if drag racing?
Because I'm lazy and can't be bothered swapping from one to the other and back again before and after winter :D
Also because I'm not having any cooling problems. Stock rad seems to be ok. I'll reconsider if 500hp makes it too warm!
You don't change twice a year anyway? I changover 4 times a year generally.
500 bhp produces a lot of heat energy ,more so than a 300 bhp engine the extra heat must go somewhere
out the exhaust,into the oil system,engine bay,and water system
=hence the fitment of oil coolers and upgraded radiators
500bhp is also not cheap to achieve ,so why wouldnt you protect your "investment" with a simple change to the anti freeze during the summer - or reducing the content during the winter?
"the stock rad seems ok"
based on the water temp gauge I guess.what would the oil temp be doing? if the water system is at its max capacity?
T67 single turbo, big Blitz FMIC (ducted), stock original radiator, no overheating problems :shrug:
Oil temps don't get much past 105degC.
Oh and I use Toyota red coolant, always have. I change it if I have to drain it for other engine work and that's it.
I'll worry about overheating when it overheats ;) Maybe the reverse vented louvres in the bonnet actively suck hot air out the engine bay though, it's a seriously low pressure area. Hmmm.
-Ian
"the stock rad seems ok" based on the water temp gauge I guess.what would the oil temp be doing?
My array of K type thermocouples will tell me what is going on ;)
Once I fit them all.... not a task I'm looking forward to!
