jevansio Posted May 11, 2007 Share Posted May 11, 2007 As Michel took delivery of the car last week and work has started I thought I'd post up my Single Turbo story. First the full spec of the car will be: Built Engine Eagle H-Beam Rods Aries Pistons 86.5mm Coated ARP Main Bolts ARP Head Bolts Clevite Bearings Balanced Crank Engine Honed & Decked Modified Oil Channels New Oil Pump New Water Pump PE Timing Belt & Fan Belt BL Crank Pulley Polsihed Fan Belt Pulleys Built Head Greddy Polished Inlet Manifold Q45 Polished Throttle Body HKS Cams (264 In/Ex) AEM Cam Gears Ferrea Valvetrain Ported Head Turbo & Exhaust Precision GT4088R 0.68 A/R HKS Cone Filter (located in stock SMIC area) SP Tubular Manifold - Heat Wrapped SP Downpipe & Midpipe 3" HKS 60mm Wastegate (No Screamer) HKS Titanium Racing 4" Exhaust Tial Dump Valve Turbo Blanket Electronics Blitz DSBC @ around 1.4 BAR AEM ECU with 3.5 BAR MAP Sensor AEM Wideband O2 Kit Defi BF Blue Full Gauge Setup with Indicator including Oil Temp, Water Temp, EGT, Fuel Press, Oil Press & Boost HKS DLI Slimline Gel Battery with relocation kit Cooling XS Power 4" FMIC with Hardpipes Koyo Radiator with Blitz 1.3 BAR Cap AAP Twin Fans Polished TRD Thermostat Mocul Oil Cooler with Relocation Kit Power Steering Cooler Fuel Precision 880cc Injectors Walbro Twin Fuel Pumps HKS Fuel Rail Fuel Lines/Fittings Aeromotive Filter Aeromotive FPR Drivetrain RPS Stage 3 6 Puck Clutch RPS Cyn-R-G Segmented Flywheel Brakes (Front & Rear) UK Calipers 3G Grooved Disks Hawk Pads Goodrigde Braided Hoses 5.1 Fluid Suspension RS-R Sports-I Coilovers Whiteline ARBs Interior Momo Handbrake & Leather Gaitor Momo Gearknob & Leather Gaitor Custom Dash Mount for 6 Defi's Other Mapping by Dan Turbo/Head Gaskets Silicone Hoses in Blue Most Pipework Power Coated Fresh Oil / Plugs Coolant Gearbox Oil Diff Oil Some brands may be wrong on the smaller parts but the major parts are correct. Pics to follow shortly. Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 11, 2007 Author Share Posted May 11, 2007 In answer to Homer question which was destroyed with the restore, boost will be around 1.6 BAR, rev limit will be 7200 rpm Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 11, 2007 Author Share Posted May 11, 2007 Work has started to get the old engine out, parts have been sent off for polishing. Old cams don't look too bad either Quote Link to comment Share on other sites More sharing options...
Shilakadaddy Posted May 11, 2007 Share Posted May 11, 2007 subscribed When complete I think your car will be exactly how I would want mine to be Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 11, 2007 Author Share Posted May 11, 2007 Thanks Chris, will be getting pics all the way through the build, target date for mapping is 8th June. Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 12, 2007 Author Share Posted May 12, 2007 Just added Polished Greddy Inlet Manifold & Q45 Throttle Body to the list Been down to Storm today with Michel, Stu & Ian. Engine is now out, bit of paintwork going on in engine bay area to bring it up nice, new engine target fitting date is next Saturday, polsihing my old inlet manifold was going to be a hold-up, but now I'm getting Michels old Greddy that won't be an issue Stu showed me the Tial BOV we'd be using & the polished pulleys (the ones he's using on his monster Supe so good enough for me) Quote Link to comment Share on other sites More sharing options...
DannyW Posted May 12, 2007 Share Posted May 12, 2007 Who's a lucky boy then huh? Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 12, 2007 Author Share Posted May 12, 2007 Feels like all my Xmas's have come at once man Quote Link to comment Share on other sites More sharing options...
JamieP Posted May 12, 2007 Share Posted May 12, 2007 Nice spec, good luck with it:) Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 12, 2007 Author Share Posted May 12, 2007 Cheers Jamie Quote Link to comment Share on other sites More sharing options...
mr keef Posted May 12, 2007 Share Posted May 12, 2007 oooooo i love threads like this... .....sounds great hope everything goes to plan mate:) Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted May 12, 2007 Share Posted May 12, 2007 Good luck with your mods m8y Is that the stock oil cooler in the right headlight shot? - looks a bit manky whatever it is And whats that muck on your cams? Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 12, 2007 Author Share Posted May 12, 2007 Cheers Mr Keef & Bobbeh, it is a stock oil cooler but is being used as a PAS cooler Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted May 12, 2007 Share Posted May 12, 2007 Ooo, I never knew it was there Good idea with the PAS cooler Where are you mounting the oil cooler? Further down? Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 12, 2007 Author Share Posted May 12, 2007 I don't think that's the stock location of an oil cooler, we just put it there for ease of running the PAS fluid lines, I think the real oil cooler will be mounted behind the FMIC Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted May 12, 2007 Share Posted May 12, 2007 Oh right.. fair do's Keep us updated! Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 15, 2007 Author Share Posted May 15, 2007 Just been down to Storm to see the latest progress. Engine is now out, bit more spray work has been done to tidy the engine bay up, alternator etc sprayed black, the rest of the engine bay is getting similar treatment so the final result should be pretty smart. Geordie Steve's car in the background there in pic 2: This is my old engine & gearbox out, it's got the polished cam cover on that will be going on the new engine: Here's the polished Greddy inlet that's going on (came from Michel, thanks buddy), should release a few more ponies. I'll be getting his polished Q45 throttle body too: Now my favourite bit, Precision GT4088R 0.72 A/R compressor, 0.68 A/R turbine, Big thanks to Stu for just starting his car up!!!!!! I've never heard anything like that before, fantastic car mate. Ian I'll bring some chocy bics on Saturday Quote Link to comment Share on other sites More sharing options...
b_have Posted May 15, 2007 Share Posted May 15, 2007 Wow, perfect spec imo. Quote Link to comment Share on other sites More sharing options...
Nic Posted May 16, 2007 Share Posted May 16, 2007 Nice choice of Turbo Jay Looking good so far, how long do they reckon the install will take? Quote Link to comment Share on other sites More sharing options...
neil tt Posted May 16, 2007 Share Posted May 16, 2007 That looks amazing, looking good so far:d Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 16, 2007 Author Share Posted May 16, 2007 Thanks chaps, Nic, hopefully the new engine should be back in Sat / Mon. It is being mapped 8th June so that is in effect how long the whole install will take (as I won't get the car back until then). Quote Link to comment Share on other sites More sharing options...
Nic Posted May 16, 2007 Share Posted May 16, 2007 jevansio said: Thanks chaps, Nic, hopefully the new engine should be back in Sat / Mon. It is being mapped 8th June so that is in effect how long the whole install will take (as I won't get the car back until then). Just had a look through the spec list, should make for some good numbers when she's done. Good luck Quote Link to comment Share on other sites More sharing options...
jevansio Posted May 21, 2007 Author Share Posted May 21, 2007 Another update, engine, head & gearbox are now assembled, inlet manifold is on. HKS cam gears have been swapped for AEM ones, but I'll be changing them for 5 bolt ones in the future anyway: Quote Link to comment Share on other sites More sharing options...
wkdtime Posted May 21, 2007 Share Posted May 21, 2007 It's really all coming together now, your in safe hands with Michel. Exact set up as mine bar the ECU and Build, you'll love that turbo, the size along with the A/R size is spot on for the 6 Speed:) Quote Link to comment Share on other sites More sharing options...
Marty Posted May 21, 2007 Share Posted May 21, 2007 Taking shape matey Cant wait to see the finished product, its going to be a beast Quote Link to comment Share on other sites More sharing options...
