Loose Sub-Frame question.
Hak
Hi guys,
I believe that my front sub-frame bolts are loose as the car makes a clunking noise when parking. It always clunks once when going from fwd-reverse and vice-versa especially when the brakes are applied.
My question is, when I tighten the bolts should I stop the car in fwd? or reverse? As I guess the frame will be in two slightly different positions. I hope that makes sense.
Thanks.
  • 3 weeks later...
Spent some time under the car and couldnt find anything loose.
If it was the pads moving would'nt I feel it in the brake pedal? How do u stop pads from moving??
Thanks
I got almost half a turn on mine, inner and outer...well steveyboy did ;) there torqued up to sill numbers....
Sorry Mikey, didnt get u..??
Are you talking about pads?
I've got exactly the same problem with mine been under the car a few times now tightening the subframe bolts if i remember correctly the 19's bolts are 200Nm and the 17's are around 148Nm .
The search will give you the exact figures , Though on on of the diagrams it shows 8x19 bolts but for the life of me i can only find 6 .
I think i'll check my brake pads but from the noise my car makes i think its more than just the pads , just hope its not the bottom arms or something like that at £200 + vat each .
No, but it sounds more like pad movement, or worn sliders if it's on Jap spec brakes/
This noise is really bugging me cos its getting embarrassing!
I was doubting the brakes because I couldnt feel it through the brake pedal - good/bad assumption - I dont know...? opinions please….
Also got my mate to drive it and it sometimes comes the front left and sometimes from the front right - but in both cases it sounds like its coming from underneath and not from the wheels - but its hard to tell.
Cheers
