DL Wide front wings (New)
Joe.
Are these wider than stock wings? Or are they just 'show'?
I think they're the same width but a slightly different taper towards the front making them look wider and then cutting in at the head light.
Really? That would be nice, i wouldnt want my front wheels to not stick out far enough. Spacers are a no go for me. Heading to the left a bit here, but do they fit using the stock locating points and bolts?
So they in theory overhang the wheel by 25mm then? :(
Mr Man, do luck on its way. Well actally it should have been here two weeks ago :rolleyes:
Should be fine for you then mate.
As far as i can see, the +25mm is basically just at the front where it hasn't tapered in as much as stock wings....doesn't look like they're any wider else they'd flare out further than the doors and look a bit daft...no?
