Bits from My rebuild, engine ect
johnd-mkiv
My car is a 1993 manual twin turbo with just over 60K
As im having a new engine built to take the new single I will be selling my engine that is currantly in the supra, it has around 60k on it with regular oil and filter changes, no smoke runs sweet as a nut ;) ill be selling this complete with the turbos ect so it willl be a straight drop in to your own, Test rides are more than welcome but I will be driving!! also a compression test can be supplied when the engine is removed. The engine will be removed at GBH motorsport within a week or two so thought it best I posted this now if any one wanted to veiw it in the car.
Looking for the going rate on this ??????
the rad is coming out as I have a koyo going in £80
6 speed flywheel (may need skimming) £80
Front J spec calipers painted in foliatec heat paint with a silver supra sticker on each £50
Just a few bits at the mo but will have more later as soon as they come off the car
what is the going rate? on the engine ;-)
is it just the engine or will the stock ecu and wiring loop becoming out?
is the engine Stock or been modded?
(questions asked as if i do buy i want to drop into a N/a)
