RobDogg Posted May 8, 2007 Share Posted May 8, 2007 I think my disks are knackered and may need replacing. I had a problem on sunday when I got back from Reading it looks like my caliper on the rear has seized slighlty causing friiction and my pad and disk are knackered. It is in the garage now being looked at. Any idea how much a new disk will cost me and where is best to get one from or is anyone selling any second hand ones. I have the smaller sized jap brakes as well. I will try and get some pics for you tonight so you can see the damage. Quote Link to comment Share on other sites More sharing options...
Wez Posted May 8, 2007 Share Posted May 8, 2007 For stock units speak to Steve Manley in my sig Or do a search and find out what people think of the various after market jobbies. Quote Link to comment Share on other sites More sharing options...
Dr_Doom Posted May 8, 2007 Share Posted May 8, 2007 Hi mate, i've had quite a few problems with my brakes this past month Are you sure the discs are knackered? They might be ok, they can take a fair beating. Were they worn badly? My front brake was binding on the way to Derby, when i pulled over to check it, it was glowing red & when it cooled down the disc had turned blue.. oops! Yours might be ok unless they have grooves worn in them, or they are warped (vibrating through the pedal when you brake). I'm pretty sure a set of rear discs will set you back around £100 but should be able to pick a second hand set up cheaply as people are always upgrading to UK spec.. Quote Link to comment Share on other sites More sharing options...
RobDogg Posted May 8, 2007 Author Share Posted May 8, 2007 There are some pics of my brakes here http://www.robertlee.plus.com/index.html Could someone tell me how you post a picture in your message? Can someone tell me if they look knackered or not and also if they are the smaller jspec type. I think they are. Quote Link to comment Share on other sites More sharing options...
Bobbeh Posted May 8, 2007 Share Posted May 8, 2007 Rob, if your pics are small (in size) you can attach them as part of the message, otherwise you can use IMG tags around the url for the picture if you have it hosted on some webspace. Quote Link to comment Share on other sites More sharing options...
