Twin Turbo Jim Posted May 7, 2007 Share Posted May 7, 2007 Anybody know the settings for the apexi SAFC? It was installed on my car when it came from Japan but no instructions, not had much luck finding setting on the web but i did find a warning that the wrong setting can damage your engine. Or can anyone recomend anywhere, a rolling road, tuning company that know about this stuff and not more than 100 miles from Bristol area. Any help will be much appreciated. I am running standard turbos with both decats and HKS exhaust, uprated fuel pump and FCD and front mount big intercooler. Running 367BHP but after more 400+ Link to comment Share on other sites More sharing options...
SupraAyf Posted May 8, 2007 Share Posted May 8, 2007 I wouldn't just stick a few 'off-the-shelf' settings in to one of those things IMHO as you need to ensure the set-up is done correctly mate. Your car sounds great but the wrong inputted setting could soon change that;) Link to comment Share on other sites More sharing options...
Twin Turbo Jim Posted May 8, 2007 Author Share Posted May 8, 2007 I wouldn't just stick a few 'off-the-shelf' settings in to one of those things IMHO as you need to ensure the set-up is done correctly mate. Your car sounds great but the wrong inputted setting could soon change that;) So need an expert rolling road. Any suggestions? Link to comment Share on other sites More sharing options...
Nic Posted May 8, 2007 Share Posted May 8, 2007 Instruction manuals can be downloaded from here http://www.apexi-usa.com/support_installation.asp Link to comment Share on other sites More sharing options...
Twin Turbo Jim Posted May 8, 2007 Author Share Posted May 8, 2007 Instruction manuals can be downloaded from here http://www.apexi-usa.com/support_installation.asp Cheers Nick Link to comment Share on other sites More sharing options...
Sheefa Posted May 8, 2007 Share Posted May 8, 2007 Turbofit in Milton Keynes mate. They use an in-house mapper called Dan you can map pretty much everything, even an F22-Raptor fighter Jet Check http://www.turbofit.co.uk. Greg Link to comment Share on other sites More sharing options...
gregsupra4 Posted May 8, 2007 Share Posted May 8, 2007 Turbofit in Milton Keynes mate. They use an in-house mapper called Dan you can map pretty much everything, even an F22-Raptor fighter Jet Check http://www.turbofit.co.uk. Greg Mind you he had a bit of a problem trying to get the jet to maintain constant boost over 200Bar something to do with the wastegate I believe. Link to comment Share on other sites More sharing options...
