JamieP Posted May 7, 2007 Share Posted May 7, 2007 Anyone know much about these? ive been offered a good deal on one. No search feature on supraforum. Link to comment Share on other sites More sharing options...
Jezz Posted May 7, 2007 Share Posted May 7, 2007 Yup. Good piece of kit if put together properly, revs to 8500 safely. Only issue i have with it, is you have to destroy a stock crank as the BC crank has no oil drive. HKS and the more pricey kits have the oil drive already in place. 95% sure i'm going with this too though. If you work out the cost of a full rebuild using CP and Carillo etc, a few £100 more will get the BC kit. Gotta be worth a pop. Link to comment Share on other sites More sharing options...
JamieP Posted May 7, 2007 Author Share Posted May 7, 2007 Where's the oil drive on the crank then? Link to comment Share on other sites More sharing options...
Jake Posted May 7, 2007 Share Posted May 7, 2007 Dunno if it help, for info: http://www.supraforums.com/forum/showthread.php?t=394692 http://www.supraforums.com/forum/showthread.php?t=397391 Link to comment Share on other sites More sharing options...
Jezz Posted May 7, 2007 Share Posted May 7, 2007 Where's the oil drive on the crank then? The splined section, pulley end, that drives the oil pump. Apparently has to be 'sweated' off a stock crank, then re-pressed onto the BC crank. Easy enough though so i hear. I had a long 'pro's and cons' email from Dusty about this, but i lost it when i moved isp's. Link to comment Share on other sites More sharing options...
JamieP Posted May 7, 2007 Author Share Posted May 7, 2007 Dunno if it help, for info: http://www.supraforums.com/forum/showthread.php?t=394692 http://www.supraforums.com/forum/showthread.php?t=397391 Thanks Jake, that will keep me busy for a while. Link to comment Share on other sites More sharing options...
JamieP Posted May 7, 2007 Author Share Posted May 7, 2007 The splined section, pulley end, that drives the oil pump. Apparently has to be 'sweated' off a stock crank, then re-pressed onto the BC crank. Easy enough though so i hear. I had a long 'pro's and cons' email from Dusty about this, but i lost it when i moved isp's. Cheers Jezz. Link to comment Share on other sites More sharing options...
Jezz Posted May 7, 2007 Share Posted May 7, 2007 Cheers Jezz. Discount for 2, and save on p+p should you decide on one. Link to comment Share on other sites More sharing options...
JamieP Posted May 7, 2007 Author Share Posted May 7, 2007 Discount for 2, and save on p+p should you decide on one. Ill let you know;) Link to comment Share on other sites More sharing options...
JamieP Posted May 7, 2007 Author Share Posted May 7, 2007 Jezz was you looking at using stock or billet main caps? as once you add it all up it does work out a fair few $. Link to comment Share on other sites More sharing options...
Jezz Posted May 7, 2007 Share Posted May 7, 2007 Billet mains. I just thought i'd take advantage of the $ being so crap at the mo, plus Mr Turners horror stories of the HKS stroker. Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 8, 2007 Share Posted May 8, 2007 Be VERY careful where you buy a 3.4 crank from!!! They have very little big end to main journal overlap at that stroke. You MUST buy a crank made from seriously good material like S312 vacuum melt none miraging steel. VERY few makers offer this. You can get away with EN40 at stock or maybe even 3.2 strokes, but at 3.4 you need something quite trick. I can offer cranks in S312 fully finished at YOUR desired stroke, heat treated and balanced for 2250 plus VAT In EN40 they are 1650 plus VAT, Rods to suit are 170 each, plus VAT, fully finished and balanced with proper rod bolts. 8 to 10 week delivery on cranks at the moment. I have one in my Skyline engine, if anyone wants pics. Link to comment Share on other sites More sharing options...
JamieP Posted May 8, 2007 Author Share Posted May 8, 2007 Thanks chris but ive decided to go for the BC kit now. Link to comment Share on other sites More sharing options...
bolarbag Posted May 8, 2007 Share Posted May 8, 2007 Didnt you just rebuild your engine m8? Link to comment Share on other sites More sharing options...
JamieP Posted May 8, 2007 Author Share Posted May 8, 2007 Didnt you just rebuild your engine m8? Yea but ive been offered a deal i cant refuse, ill be kepping mine though incase i have any problems with the stroker kit. Link to comment Share on other sites More sharing options...
Kranz Posted May 8, 2007 Share Posted May 8, 2007 Didnt you just rebuild your engine m8? Yeah, but that's just so yesterday now I too struggle to keep up with the current spec of Jamie's car. Maybe there should be a seperate thread titled "This week my car will mainly be....." Link to comment Share on other sites More sharing options...
tooquicktostop Posted May 8, 2007 Share Posted May 8, 2007 Yea but ive been offered a deal i cant refuse, ill be kepping mine though incase i have any problems with the stroker kit. I dont mind looking after your built engine for you and keeping it run in while you play with a stroker 3.4 Link to comment Share on other sites More sharing options...
Bobbeh Posted May 8, 2007 Share Posted May 8, 2007 You know you'll be wanting a much bigger turbo once you go 3.4 His build is endless! Link to comment Share on other sites More sharing options...
Stevie Boy Posted May 8, 2007 Share Posted May 8, 2007 Yeah, but that's just so yesterday now I too struggle to keep up with the current spec of Jamie's car. Maybe there should be a seperate thread titled "This week my car will mainly be....." Link to comment Share on other sites More sharing options...
JamieP Posted May 8, 2007 Author Share Posted May 8, 2007 This aint a 2 min thing, the engine wont be done for a while yet and yes i know ill be wanting a bigger tubby, watch this space;) Link to comment Share on other sites More sharing options...
Bobbeh Posted May 8, 2007 Share Posted May 8, 2007 /me sings "Neverending Storeeey, na na naaa na na naaa na na naaaa" Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 8, 2007 Share Posted May 8, 2007 What's "BC"? Link to comment Share on other sites More sharing options...
JamieP Posted May 8, 2007 Author Share Posted May 8, 2007 What's "BC"? http://www.briancrower.com/makes/toyota/2jzgte.shtml Link to comment Share on other sites More sharing options...
Chris Wilson Posted May 8, 2007 Share Posted May 8, 2007 Thanks. Pins retained by buttons eh? Oh dear oh dear, still, it IS a Yank made kit.... Link to comment Share on other sites More sharing options...
JamieP Posted May 8, 2007 Author Share Posted May 8, 2007 Thanks. Pins retained by buttons eh? Oh dear oh dear, still, it IS a Yank made kit.... Are you saying the kit is no good then Chris? Link to comment Share on other sites More sharing options...
