speed to revs ratio
I was talking with a few members at Turbofit BBQ about the pod runs and how I should have not needed to use 5th Gear at all, I was at red line with around 300m to go in forth and had to grab 5th, but my terminal speed was only 107mph
I have a 6speed conversion and was wondering if anyone had the speed to revs ratio for the standard set up and am i missing something ??:search:
Maybe, you tried doing top speed run in it? , i never knew greg had and old supe? i had his spare diff when i broke mine at ace.
I am getting knowhere near 130 in 4th, Greg sold me the diff from his car he told me, I know at the time he was breaking one for a member on here, perhaps it was from that car, I am feeling more certain that I dont have a 6 speed diff now :rolleyes:
I would have thought Dan might have noticed when mapping though ??
I *Think* the UK diffs have a different ratio, do you know if your conversion came from a UK or Jspec car? Also, do you know for sure its an LSD diff? I'm sure you know how to test this :D
Is the gearbox a V161? They have a lower ratio in the first 4 gears.
Mine was on the stock limit at around 120mph (GPS, not speedo)
Not sure where the diff came from now will have to check this out with TF, This may explain why I was finding it so difficult to break 14 seconds at the pod with my set up !
Ahh yea i know what car that diff come and was deffo a 6 speed, unless the guy had changed it.
What car is the V161 box out of?
Jamie, was it a car from here? Do you know the spec of it and year?
I dunno mate.
