hodge Posted May 5, 2007 Share Posted May 5, 2007 My new engine arrived the other day and ive compard it to the 1 thats in and theres some minor differences, can anyone please explain why. The water pump seems different, theres a great big chuffing sensor sticking out of it, which mine doesnt have. Also the turbo pipes are also different to the re-cerculating valve. The valve is bolted like a flange type fit the the pipe but mine just connects with 2 pipes. Odviously i can just change the water pump and boost pipes for the ones from my own engine but am wondering why they are different. Were there any engine components changed at any point. My car is a J-spec 1994 TT engine. Link to comment Share on other sites More sharing options...
Thorin Posted May 5, 2007 Share Posted May 5, 2007 Pics? Link to comment Share on other sites More sharing options...
bignum Posted May 5, 2007 Share Posted May 5, 2007 The pipe on the waterpump is a drain incase the seal leaks water is diverted away from your alternator Link to comment Share on other sites More sharing options...
hodge Posted May 5, 2007 Author Share Posted May 5, 2007 Heres a pic of the water pump, and a couple of the boost pipes, not the best pics as i took them with my phone. Link to comment Share on other sites More sharing options...
Jake Posted May 5, 2007 Share Posted May 5, 2007 Is that an Aristo TT engine? Link to comment Share on other sites More sharing options...
bignum Posted May 5, 2007 Share Posted May 5, 2007 I think thats a Hilux motor lol:d Link to comment Share on other sites More sharing options...
hodge Posted May 5, 2007 Author Share Posted May 5, 2007 That wont make any difference if it an aristo engine will it.I will just be able to swap the water pump and the boost pipes and it will be fine or is there anything else i will need to change. Link to comment Share on other sites More sharing options...
D8MOA Posted May 5, 2007 Share Posted May 5, 2007 just swap it all over and you should be fine Link to comment Share on other sites More sharing options...
Thorin Posted May 5, 2007 Share Posted May 5, 2007 Is that an Aristo TT engine? Ahh I believe you're correct yeah. Link to comment Share on other sites More sharing options...
hodge Posted May 5, 2007 Author Share Posted May 5, 2007 Great thanks guys. The transplant starts on Tuesday. Link to comment Share on other sites More sharing options...
colsoop Posted May 5, 2007 Share Posted May 5, 2007 John as above its an aristo engine, i believe the intake manifold is slightly different too, it doesn't have the top feed for the brake booster. Link to comment Share on other sites More sharing options...
LuxobargeTT Posted May 5, 2007 Share Posted May 5, 2007 Yeh, aristo lump, as above plus the sump is different also Link to comment Share on other sites More sharing options...
hodge Posted May 5, 2007 Author Share Posted May 5, 2007 The sump on the new engine is dinted slightly,does this mean I cant replace it with the sump off my Supra engine. Link to comment Share on other sites More sharing options...
LuxobargeTT Posted May 5, 2007 Share Posted May 5, 2007 You need to put a Supra 2JZ sump on it. The Aristo 2JZ has a sump at the front of the engine, where the Supra 2JZ has a rear/off center sump. Link to comment Share on other sites More sharing options...
