Andy Supra Posted May 4, 2007 Share Posted May 4, 2007 I need to send off for a V62 as i've lost my V5 log book. Where is says chassis, frame or vin number do I put in the whole frame number? Ie. VIN plate stats JZA80 - 000xxxx (blanked numbers as don't know how important they can be) Or just the the numbers? Wondered if anyone could look at there log book and let me know what sort of code shows so I make sure i'm putting the correct one in the box. Also found on the door a code thats 3/22 - 84863 - PMXE? Thanks in advance. Link to comment Share on other sites More sharing options...
Andy Supra Posted May 4, 2007 Author Share Posted May 4, 2007 Ah did a VIN check using the JZA80 code and it confirmed the VIN number to the registration to confirm thats correct. Then looked on the MOT certificate and that states the JZA80 - number as being the VIN Number. Worried at first as it says this is usually a 17 digit code and got scared it was going to be that weird Jap writing at the bottom of the vin plate I needed Link to comment Share on other sites More sharing options...
