Jurgen-Jm-Imports Posted August 31, 2004 Share Posted August 31, 2004 does anybody know were this is i try looking near the throttle and air pipes cant find anything, can u help me its ticking over at 600rpm need to adjust it . thanks Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 31, 2004 Author Share Posted August 31, 2004 need some help i have tried the search my car is now dropping to about 400 and nearly cutting off but when am driving its fine all i need is to turn tick over up please somebody help Quote Link to comment Share on other sites More sharing options...
chazuk Posted August 31, 2004 Share Posted August 31, 2004 Hmm I could be wrong but dosen't the ECU control the rpm ?/.. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 31, 2004 Author Share Posted August 31, 2004 i hope not any more suggestions otherwise colud be ecu fault or needs setting Quote Link to comment Share on other sites More sharing options...
CJ Posted August 31, 2004 Share Posted August 31, 2004 I think my first port of call would be to pull the ECU fuse in the main fuse box. Leave it for a minute or so and see if it then resets itself. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 31, 2004 Author Share Posted August 31, 2004 yes somebody is helping me thanks cj a will try that and see what happens mate Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 31, 2004 Author Share Posted August 31, 2004 dont want to sound stupid but i checked on the engine bay and does not appear to have a fuse for ecu in that fuse box and therefor am stuck again Quote Link to comment Share on other sites More sharing options...
CJ Posted August 31, 2004 Share Posted August 31, 2004 The main fuse holder is on the passenger side near the front of the engine bay. The ecu fuse is one of the 30 amp ones. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 31, 2004 Author Share Posted August 31, 2004 right am going to have a look again am sure on the box i didnt say ecu but i will pull out 30 ampers for a bit cheers mate Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 31, 2004 Author Share Posted August 31, 2004 i have now tried that , they are called efi 1 and efi 2, anyway it seem to be ok bearing in mind it maybe the cold start and i wont really know till it warms up and i drive it home but its looking promosing thanks mate will post on here later on to confirm. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted August 31, 2004 Author Share Posted August 31, 2004 well that doesnt do the trick unless i pulled wrong fuses, but mine has only 2 30 amp ones any other ideas Quote Link to comment Share on other sites More sharing options...
chazuk Posted September 1, 2004 Share Posted September 1, 2004 How long did you leave the fuse out for as I know ECU hold there memory for a while >?.. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted September 1, 2004 Share Posted September 1, 2004 Just disconnect the battery for 10 minutes and switch on the ignition for a second whilst it's disconnected to drain any residual power from the ecu. I don't think it will help though, you will probably need to remove the idle control valve and wash it out in clean petrol, perhaps leave it to soak overnight in petrol. They gum up inside. Blow out with air before refitting. That usually fixes them. Otherwise the throttle pot may need resttting, but BEFORE doing this make sure you have all the info and voltages to hand, and check for fault codes first in case it's something else. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted September 2, 2004 Author Share Posted September 2, 2004 were is the idle control valve Quote Link to comment Share on other sites More sharing options...
Syed Shah Posted September 4, 2004 Share Posted September 4, 2004 If your getting desperate, you could tighten the throttle cable a little, so that it is open a crack already. Quote Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted September 6, 2004 Author Share Posted September 6, 2004 sometimes its ok but then it plays up am hoping it sorts it self out Quote Link to comment Share on other sites More sharing options...
