Car won't start - Wet??
JamesArup
Was there any corrosion on fuse or in the fuse holder? That can cause problems in the electrical dept. ALso if you can have a look at the bottom of the fusebox see if there is any corrosion under there. The rubber strip I am assuming that peep are talking about is the one that runs under the front edge of the bumber between the lights?
Hmmmm - I had best try and find one of these rubber strips then!
I do have the rubber stip at the front of the bonnet? The one, as Dangerous says, that goes between the lights? I just don't have one down the sides of the bonnet.
I didn't check for corrosion really, no. It was about 11pm and my torch battery was dying - LOL. I'll have a look today though.
Cheers, J :cool:
The bonnet gap pic shows where a rubber stip should be, front of the bonnet against the font of the bumper inbetween the lights.
I'm fairly certain I don't have a rubber strip along the side of the bonnet, I'll check later for you.
