dangerous brain Posted September 1, 2004 Share Posted September 1, 2004 Was there any corrosion on fuse or in the fuse holder? That can cause problems in the electrical dept. ALso if you can have a look at the bottom of the fusebox see if there is any corrosion under there. The rubber strip I am assuming that peep are talking about is the one that runs under the front edge of the bumber between the lights? Quote Link to comment Share on other sites More sharing options...
JamesArup Posted September 1, 2004 Author Share Posted September 1, 2004 Hmmmm - I had best try and find one of these rubber strips then! I do have the rubber stip at the front of the bonnet? The one, as Dangerous says, that goes between the lights? I just don't have one down the sides of the bonnet. I didn't check for corrosion really, no. It was about 11pm and my torch battery was dying - LOL. I'll have a look today though. Cheers, J Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted September 1, 2004 Share Posted September 1, 2004 You should have a rubber strip at the front lip of the bonnet, and at the rear of the bonnet, but I've never seen anything down the sides of the wings on any Supra... Quote Link to comment Share on other sites More sharing options...
Nick Posted September 1, 2004 Share Posted September 1, 2004 The bonnet gap pic shows where a rubber stip should be, front of the bonnet against the font of the bumper inbetween the lights. I'm fairly certain I don't have a rubber strip along the side of the bonnet, I'll check later for you. Quote Link to comment Share on other sites More sharing options...
