Tricky-Ricky Posted May 2, 2007 Share Posted May 2, 2007 Which is the lambda signal input 48 or 71? Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted May 2, 2007 Share Posted May 2, 2007 http://www.mkivsupra.net/vbb/attachment.php?attachmentid=13918&d=1112558155 Hmm both of them? Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 2, 2007 Author Share Posted May 2, 2007 Thanks, got the diagram, thats the reason for the question, there can only be one. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted May 2, 2007 Share Posted May 2, 2007 I can't remember is there 1 or 2 O2 sensors? Quote Link to comment Share on other sites More sharing options...
Wez Posted May 2, 2007 Share Posted May 2, 2007 EDIT: deleted as it might be complete cr@p Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 2, 2007 Author Share Posted May 2, 2007 The J spec pin out has two O2 inputs but one of them must be a + heater feed, but which?? Quote Link to comment Share on other sites More sharing options...
Soop Dogg Posted May 2, 2007 Share Posted May 2, 2007 Pin 48, OX1 I believe. Quote Link to comment Share on other sites More sharing options...
Wez Posted May 2, 2007 Share Posted May 2, 2007 48B is the one you want. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted May 2, 2007 Share Posted May 2, 2007 The J spec pin out has two O2 inputs but one of them must be a + heater feed, but which?? Well HT1 would suggest that 71 is the heater + to me Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted May 2, 2007 Author Share Posted May 2, 2007 Thanks, thought it would be 48, just wanted to get some more opinions;) then i can moan at you guys if it goes wrong:p Quote Link to comment Share on other sites More sharing options...
