Dipped beam bulbs - facelift - not 9006
merckx
All of the searches on the net and on here point to the "9006 " bulbs being the ones for the dipped beam.
I got some Phillips Premium 9006 for my 97 my facelift lights-dipped beam and they don't fit
Here's a place to get them, quick delivery.
http://www.powerbulbs.com/index.htm
The "O" ring on the boss should provide a snug fit, but was about 2mm too big.
The photo shows a 9006 bulb (not the actual one)
9006
I had to remove the "O" ring and reduce the diameter of the boss, I refitted the "O" ring even though I had removed the groove that it used to sit in.
They fit okay but they definately aren't designed to fit the facelift dipped beam.
Next time I need some bulbs for the healights I'm going to go to Halfrauds and measure some first to make sure they fit!
Using 9005 in both is the key, it's easy then. The dipped beam is still not as bright as some new cars, and much better than standard. Remember the full beam is so bright because you have the dipped lights plus the main beams on too.
